transmission won't go forward
Old 04-26-2014, 05:55 PM
anthony sanders's Avatar
Default transmission won't go forward
hi guys I'm new Have a 1999a6 we'll go in reverse and move won't go forward will make a lot of noise like Gears of scraping
Old 04-26-2014, 06:28 PM
Tech Guru
4Driver4's Avatar
Bad CV joint.
Old 04-26-2014, 07:34 PM
redbullgotwings's Avatar
Automatic or manual? Does it go into gear and try to move or just wont go into gear? If it goes into gear and tries to move but wont you better hope its the CV joint, could be the trans. I usually trust the guru but wouldnt the rear tires still drive even if the front cv joints were totally gone?
Try to listen inside the car and out and tell us where the sound is coming from.
Old 04-28-2014, 03:30 AM
Originally Posted by 4Driver4
Bad CV joint.
automatic transmission.
transmission and I disconnected the drive shaft on the front of the on the differential side gears and scraping. like run around and you put your hand on it stop the wheel
Old 04-28-2014, 04:24 AM
SloopJohnB@mac.com's Avatar
What we have here is a failure to communicate.
You disconnected the driveshaft(s) and the other wheel rotates? Was ist das?
Old 04-28-2014, 04:27 AM
That barely makes sense. I'm sorry I tried to read it four times I dint get what you're saying. Sounds like you're describing a cv joint or maybe the transfer case?
S7ownerM&S
Wheels & Tires Discussion
06-11-2019 01:22 PM
k2exoman
05-12-2007 02:27 PM
autohausk
05-11-2006 08:04 AM
aveedotcom
12-30-2004 06:04 AM
GrandPaJohn
12-02-2003 04:02 PM
Quick Reply: transmission won't go forward
