A6 4.2 Oil Cooler
Old 05-08-2014, 08:04 PM
TorontoA64.2's Avatar
Default A6 4.2 Oil Cooler
Hi...
Can any one please tell me whether removing the right side sway bar bracket is required in order to remove the right engine mount bracket (which contains the oil cooler)?
I'm trying to remove the right engine mount bracket so that I can change the broken plastic coolant transfer pipe in the oil cooler. I did a search on the forum but most of the posts didn't give detailed procedure/information about the actual removal of the right engine mount bracket (e.g. which parts are required to be removed - e.g. sway bar bracket, engine mount, etc.?)
Most posts were about how difficult it is to remove the 5 bolts of the engine mount bracket and the tricks to get to those 5 bolts.
Thanks in advance.
Old 05-09-2014, 07:06 PM
Any one please?
Old 05-09-2014, 07:21 PM
SloopJohnB@mac.com's Avatar
Originally Posted by TorontoA64.2
Hi...
Thanks in advance.
It may not have been necessary but I did drop the sway bar brackets…both sides. Big deal…with an air wrench it take 30 seconds.
Old 05-10-2014, 05:05 AM
The problem is that I have the H-sport upgraded sway bars and if I drop the brackets, it won't be as easy to put them back on compared to standard sway bar brackets.
Anyway, thanks for replying.
A6 4.2 Vier
12-25-2018 07:44 AM
rocketman4321
12-03-2011 03:07 PM
audiquatro75
02-02-2009 10:33 AM
azndrunk74
NorCal Discussion
02-24-2006 11:02 AM
de (-eeez_nutz)
11-30-2005 05:55 PM
Quick Reply: A6 4.2 Oil Cooler
