Lower Cup Holder
Old 05-28-2007, 10:03 AM
tpk
tpk's Avatar
Default Lower Cup Holder
The lower cup holder on my 02 A6 Q 3.0 has been sticking and operating slowly for some time, I thought I would give a shot of silicone spray to get it working better. After spraying it, I lowered it and now it seems to be stuck in the down position. I have pulled on the top as hard as I dare, pushed down and attempted to pull it up, all to no avail, any ideas or tips?
Old 05-28-2007, 10:16 AM
jbchinoca's Avatar
Default Replace time. Dealer, about $50, maybe a member or ebay has one for less.
You may want to just pop it out and soak it in simple green for a while. Removal link from Stoney's Links below.
Old 05-28-2007, 10:25 AM
New Member
jsbautowholesale's Avatar
Default my $.03 fix
you can lift up the tranny console surround and push up the mirror control. After removing the mirror control you will have access to pushing up the cup holder to remove it. My cupholder broke the stay tab that keeps it down, so i dissassembled it and removed the spring. Now i can close it and it stays closed or push the opposite side and open it. If you have alot of dried coke (the drink) making it stick, soak the holder in hot soappy water for 15 minutes and clean. HTH
Old 05-28-2007, 12:53 PM
tpk
tpk's Avatar
Default Re: Lower Cup Holder
Thanks for the info, I was able to lift it up, unit now works freely except for a slight catch as it nears the lower position.
Allroadfin
Audi allroad
05-30-2020 12:52 PM
LSantos79
Audi allroad
9
05-24-2008 09:08 AM
shatiras
04-21-2004 06:19 PM
MonEl
12-22-2002 03:04 PM
KrazyKraut
09-03-2002 05:26 PM
Quick Reply: Lower Cup Holder
