ABS module and dash display
Hi,
I have a 2001 A6 Quattro 2.8. My ABS/emergency brake light go on and flash when I start the car (most of the time). Sometimes it will go off while driving and I can feel the ABS engage again. I did some research and found that this is a common problem. I've found two options and was wondering if anyone else has dealt with this a successfully fixed it. I saw there is a website (Cheap-ABS) that you can send in your ABS module and they repair it. The other option I was considering was purchasing a new one online and taking it to a mechanic to replace it. I think the mechanic quoted the repair at $1300 and I'm not sure if that included a new part. I'm not even sure if I understand if the old one can be repaired.
Also, I can't read the warning on the center display because it is faded. I've read about people replacing the LCD screen or fixing the connection (ribbons) behind it. Trying to figure out my options with this as well.
Any thoughts or experiences would be appreciated!
Thank you in advance!
Nichole
Nichole
$1300 is unsane. Get it repaired.
Hi,
Nichole
Nichole
Similarly the instrument cluster can be removed and sent to a cluster repair/overhaul facility (in the US at least) for LCD replacement. If your car doesn't have an immobilizer circuit you can even still drive the car although without instrumentation. We were able to drive the 2K4.2A6 w/o the cluster in.
I used ModuleMaster
lol I saw the "trivial" comment and was going to post , but I saw your added comment about that pain in the *** fender liner to get to two damn screws .. too true ...
even to read the number off is a PITA , if they had just put the sticker in a different location ..
JimR
11
08-05-2008 11:33 AM
Beater
12-16-2005 09:13 AM
drpboston
07-22-2005 07:31 AM
GrandPaJohn
12
06-13-2005 11:22 AM
