ABS Speed Sensor - Error
Old 05-15-2014, 07:45 AM
vitamin's Avatar
Default ABS Speed Sensor - Error
Hello,
I used vag-com and learned that my left and right rear speed sensors are bad : see report :
Code:
Address 03: ABS Brakes       Labels: 4B0-614-517.lbl
Control Module Part Number: 4B0 614 517 R
  Component and/or Version: ABS/ESP allrad      2330
           Software Coding: 06397
                 VCID: 306FE9EDF0C2A89E2B7-5122
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            30-00 - Open or Short to Plus
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
What does "Short to Plus" mean?
Thing is, I have already recently replaced these two speed sensors.
Wondering if anyone has knows if the ABS Control Module can cause failure orrrr, not sure where to go from here..
Thoughts?
Old 05-15-2014, 08:24 AM
SloopJohnB@mac.com's Avatar
Originally Posted by vitamin
Hello,
Code:
2 Faults Found:
Thoughts?
Chances are if you recently replaced the abs speed sensors you screwed up the connector to the chassis or it popped loose. Those wires are absurdly small and easily damaged…check the connector housing to see if the wires/terminals are still in the housing…they have been known to move backwards/out if the housing is damaged.
I recently had some collision work done on my S6 and three months later my left front ABS sensor had an open…I popped the wheel and checked the connector and one of the wires had broken at the chassis connector. Had to solder the wire to the terminal and switch the terminals to a new housing.
audijim113
04-04-2016 07:17 AM
blackultra
12-29-2009 12:16 PM
A4effert
02-14-2006 01:59 PM
a4avant99
10-14-2005 12:12 PM
daves4
05-01-2004 04:49 AM
Quick Reply: ABS Speed Sensor - Error
