very hot front wheel
I have a right hand drive 2002 avant 1.9 tdi 130bhp 5 speed sport susp. The front passenger wheel gets hot after a drive,Caliper even hotter. This has being happening for over three years.The pads in that side would also be more worn than the other side. I have chaged the pads then the flex pipes on both sides and lately the caliper but the same problem remains.My wife drives the car herself and see did say to me that she has noticed at times the car pulling to the left when driving.I have driven the car with this hot and jammed on the brake peddal and the car stops on a straight line.What I do know is the pads are coming in contact with the disc and this is leading to the overheating. You would not be able to keep your hand on the wheel. The car has done 143000 miles it has 16" wheels all the other three wheels are nice and cool. I find the brakes quite grabby I drive a 2007 Honda Accord 2.2 diesel and those are not grabby. One question I have is the ESP or other electronic controller causing this problem ?. One other thing the car drops out of cruise control at times on it own this might explain some of the issues.
I would start with basics.
1. are the pads installed correctly. Yes, they can be slightly out of square, i've seen it
2. are the calipers sticking ( i bet yes). They may need to be over-hauled
I don't know what flex pipes are. do you meant he flexible brake lines? When you did that might you have buggered something? I prefer not to touch them if they show no signs of deterioration.
ABS certainly COULD cause this, but without a code, i doubt it is your culprit.
I suspect a piston is not retracting.
Grant
Grant
Bad caliper one way or another. It's a floating caliper so remove it and ensure the guide pins are clean and lubricated. Blow the piston out and clean the cylinder and piston and replace the seal and dust boot. Depending on what you find, consider doing the other calipers as well.
Grant
Grant
Hi, it is only happening to the front left caliper and I have changed this but the same problem is still there. The flex pipes are the ones on to the wheel hub. All work is carried out by my local garage.I have had the car with a audi dealer and they wanted to strip the car and replace every thing..... I ran away.
