AUdi A6 radio code.
Old 08-29-2004, 03:36 AM
Bariukas's Avatar
Default AUdi A6 radio code.
I just bought Audi 1999 A6.
I had to do some work so i disconnected battary.
As now my AUDI concert radio is in SAFE mode.
I need a code. I looked at owner manual.
And on the top i saw a nuber. It was written on the top of owners manual with a marker.Can it be radio code? It is 4 digitals: 4915.
Do radio codes have any restrictions? Like: they can not start with 0 or something.
Old 08-29-2004, 03:42 AM
Bariukas's Avatar
I tried it. It does not work.
Bariukas's Avatar
Old 08-29-2004, 04:20 AM
New Member
mdcooper's Avatar
Default Which Concert Radio do you have?
Hi Bariukas,
I had the Concert I and now own a Concert II radio. The two radio's operate differently when entering the safe code. However, you are correct in saying it's 4 digits. I would consult your radio's manual, as it should say in there. If you are still experiencing problems, I can guide you through it. Just let me know which model radio you have.
Old 08-29-2004, 04:27 AM
Junior Member
bitterman's Avatar
Old 08-29-2004, 08:49 AM
New Member
Harbor A6's Avatar
Mine works. I like your sig! Go W!
Old 08-29-2004, 04:15 PM
Bariukas's Avatar
Default It is simple Audi concert I. The one like this:
http://www.ibiblio.org/tkan/audi/radios/concert.html
Old 08-29-2004, 10:55 PM
New Member
mdcooper's Avatar
Default Have you run through all the steps entering the safe code?
If you have run through all the steps entering the code correctly then I would guess that your code in incorrect and that you would need to contact you local audi dealer.
Just to confirm you have held down FM and RDS until you see 1000 appear. Then enter your code using the preset numbers 1-4. 1 being the first digit, 2 being the second and so on... This has always worked with my Concert I and Concert II radios. Let me know the outcome...
RedDragoN750
Audi 100 / A6 (C4 Platform)
11
01-19-2008 03:47 PM
anthony911
Canadian Discussion
02-24-2006 09:08 AM
jfa6
05-28-2004 04:45 AM
WhiteG60
04-25-2003 09:50 AM
myke050
03-11-2001 09:32 AM
Quick Reply: AUdi A6 radio code.
