Back Up Light Trans Linkage Adjustment
Old 12-22-2014, 08:18 AM
CRuby's Avatar
Default Back Up Light Trans Linkage Adjustment
Back up tail lights stopped working on my son's 2000 A6 2.7 6MT
Traced problem to the backup (BU) light switch mounted near top right of transmission, just near the PS front O2 sensor. Jumped the 2 wire connector & BU lights come on. So wiring to lights, & lights are OK. Removed the BU switch from the trans & its an open/closed plunger type switch linked below. Checked continuity of switch & it works fine. Barely have to push the plunger in for circuit to close & good continuity. I inspected the plunger & it's not worn or binding up at all.
So, I'm thinking the plunger switch is no longer getting pushed in when shifting into reverse. There must be a lever or such inside the trans that is supposed to push the plunger in when shifting into reverse. Is it possible this lever is worn, or out of adjustment? Attached below is pic of trans location where the BU switch goes.
Is there any adjustment on the trans for pushing this plunger on the BU switch? There is a large bolt/nut just above the BU switch location, is this for BU lever adjustment?
Old 12-22-2014, 08:57 AM
CRuby's Avatar
Also found this pic in Bentley, but still don't know if reverse linkage can be adjusted. "C" is the BU switch.
GTA_Driver
Audi allroad
01-03-2012 02:51 PM
kleinbus
Q5/SQ5 MKI (8R) Discussion
05-31-2009 03:19 PM
oostendarp
09-23-2003 08:24 PM
DINA
06-27-2003 05:26 AM
Dieselino (Jeff)
02-03-2001 09:36 PM
Quick Reply: Back Up Light Trans Linkage Adjustment
