Battery Drain - Testing of
Hi all,
I have an Audi with good battery (tested twice by two different sources).
But, it draws down pretty quickly (several days) if the car sits without charging.
I just tested to see if there is a draw with all equipment off and this is what I am seeing:
When I connect the meter, it jumps from 2.x to 6.x amps and then settles in the .2-ish amps being drawn.
Has anyone seen this? The meter jumping up to 6-ish amps being drawn when first connecting and then within 10 seconds, the meter steadies at less than one amp being drawn.
Thanks,
Thanks,
Hi all,
Thanks,
Thanks,
yeah 200ma is huge , there is a really good you tube on how to walk through the basics of troubleshooting this.
Thanks for the input. It was my mistake by not moving the decimal enough.
The draw, after things settle down (~30 seconds), stays steady at 0.05 amp which is 50mA.
The battery still seems to die quickly when sitting. I've had it tested twice...once at AutoZone and once at another Battery store. In both instances, the battery checks out "good."
I just can't figure this out!
yeah the first 30 seconds can be normal as the interior lights go out , alaram sets etc. I would think50ma is still kinda high but a good charged battery should handle this no problem. I concur with checking charging voltage as it sounds like something isn't quiteright .
The other thing you migtt want to do is try a memory meter with delta checking so you can see if the drain current goes up at some point while it is sitting .
My car occasionally would set of the alarm and drain the battery .
True-RMS AC Voltage and Current Logging Multimeter | Fluke 289
Waggin
03-16-2018 06:28 AM
USP
TT (Mk2) Discussion
07-19-2007 03:52 PM
Trick_A6
08-06-2005 08:20 AM
