Bosch 5.3 abs control module 00273004285(with 8e0614111c)internal circuit picture
I have the abs control module failure(yellow abs light up,red brake light up, tachometer won't function,no A/C),so decided to repair it myself,unfourntunly,did some damged to the PCB board,because of the alum wire is very diffcult to be weld,then I screw up with some gold wire,and I don't know how many wire should be connected,
Is there any one had the picture for 00273004285, so I can check what should I do. (I have check some picture on the web,they are for BMW or Passat or some other model, there is a slightly different. Ithought)
Thanks a lot.
Thanks a lot.
Thanks a lot.
Thanks a lot.
great picture,thanks.since I'm not in the state,so afraid that oversea shipping will cause more uexpect damage to abs itself .
by the way,is your control module P/N as same as mine 0273004285 & abs body is 8E0614111C.
Also, from your 1st thread: I don't think tachometer or A/C are affected by the ABS.
My ABS module is Bosch 5.3 p/n 273-004-284 & is on a 2000 A6 2.7T Quattro.
Here's link to MM if interested. Note that car can be driven while module is removed... of course annoying beeps & lights & no ABS. But you have that already if ABS is broken.
Bosch 5.3 ABS Rebuild | ModuleMaster
virgo193 (01-19-2021)
Bluesuede
09-07-2008 01:44 PM
ZephyrS4
02-01-2005 07:24 PM
Chuck-S4
06-05-2003 02:43 PM
