Brake Pad Questions - 6mm left??
Old 06-22-2008, 10:36 AM
  #21
WOWDee's Avatar
If it seems like u got a mouth full of gravel when braking, get r dun!!!
Old 06-22-2008, 10:47 AM
  #22
BernieBenz's Avatar
Default The caliper guide pins should be relubed at the same biennial fluid flush interval ....
Historically, I get about 100K out of OE front pads and 150K on rears.
Old 06-22-2008, 10:50 AM
  #23
BernieBenz's Avatar
You said it all!
Old 06-22-2008, 12:28 PM
  #24
jbchinoca's Avatar
Have a nice day. Stay cool.
Old 06-23-2008, 07:09 AM
  #25
FixedWing's Avatar
Trivial unless you forget to do it. :-p
Old 06-23-2008, 07:10 AM
  #26
FixedWing's Avatar
Default Lubed with what? Nothing is going to last long there...
and heat will also be an issue. I can think of only lithium grease and maybe graphite that could handle the heat.
Stephen
Old 06-23-2008, 09:38 AM
  #27
BernieBenz's Avatar
Default Not true! Nothing special about lithium grease, temp wise or other wise. I use CV joint grease...
You don't service your guide pins at regular bleed intervals?
Old 06-23-2008, 08:19 PM
  #28
Member
audikillsbmw's Avatar
Of course lube will last there. IIRC, they even make a specific grease just for guide pins.
Old 06-23-2008, 08:22 PM
  #29
Member
xryanB7
A4 (B7 Platform) Discussion
10-20-2006 01:57 PM
mattylmbr
10-10-2006 08:15 AM
finz
11
05-20-2004 10:42 AM
|everso!|
06-23-2003 11:40 PM
Nick N.
01-11-2000 05:46 AM
Quick Reply: Brake Pad Questions - 6mm left??
