Can a rebuilt CV axle assembly cause vibration?
Old 03-02-2008, 02:10 PM
vunu's Avatar
Default Can a rebuilt CV axle assembly cause vibration?
my car had a noticeable vibration when accelerating from low speed or accelerating from around 60 to 80. Also noticeable when climbing a slope, rather than just cruising at a constant speed.
This all occured right after my front passenger side CV axle assembly replacement. I checked for loose bolts and even tried another set of wheels/tires to verify that it wasn't a bent wheel or unbalanced wheel.
so, caan a rebuilt CV axle assembly cause vibration? Anyone had this kind of issue?
Old 03-02-2008, 03:40 PM
Reifle's Avatar
It can - wasn't rebuilt proper, not enough grease in boot or it could be slightly out - not true
Old 03-02-2008, 06:58 PM
socalclimber's Avatar
Default Yes - seen this in worn/bad inner CVs
I once had a VW with similar symptoms, vibration or shudder on acceleration, esp. hard acceration. It was a bad inner CV. Take car back to shop. Not all rebuilt axles are equal, some can be basic clean-up jobs (cleaned, painted, tested). Was this an audi OEM rebuilt axle?
Old 03-03-2008, 03:43 AM
Just Me's Avatar
Default Several possibilities:
1. defective CV
2. improper fit causing it to kink ( seen this)
3. inner bolts improperly seated / torqued
4. Wheel improperly seated on hub ( nothign o do with CV)
others I'm sure.
Grant
Old 03-03-2008, 04:45 AM
absolutcq20v's Avatar
If it's under acceleration/load, then I'd say the CV is shot...BTDT on a friends allroad.
Old 04-19-2010, 07:50 AM
jking's Avatar
we normally replace the axle assembly with a rebuilt unit.. sometimes improper installation can cause vibration..try to check your repair manual it will show you the diagram about axle replacement.
Old 04-19-2010, 09:21 AM
Just Me's Avatar
Sure, but dont jump to conclusions.
Its good that you checked wheels/tires - the #1 source, even when people swear they are fine.
But also consider:
- drive-shaft bolted in slightly crooked
- center/prop shaft bearing or out of balance
- drive-shaft out of balance ( would have to be a lot since it is such small diameter...)
But certainly, if there is play in the races, it can either go around eccentrically, or, worse, get out of alignment and bind.
G
clinton c
02-14-2009 06:04 PM
vunu
01-21-2008 10:12 AM
katit
13
10-28-2006 06:11 AM
AmarilloA4
06-30-2005 06:23 AM
Quick Reply: Can a rebuilt CV axle assembly cause vibration?
