Crankshaft is a little off the TDC mark, is that really bad?
Old 06-21-2016, 05:39 PM
Alex2.7T's Avatar
Default Crankshaft is a little off the TDC mark, is that really bad?
Working on a valve cover gasket replacement on my 2.7t, and while on the process of locking crankshaft with locking pin.
I got the crankshaft aligned into Top Dead Center, and both marks on crankshaft and the plastic cover mark aligned perfectly into TDC, but after pin wad installed I got my crankshaft mark a little off to the right next to the TDC aligment mark on plastic cover, is this normal?
Old 06-21-2016, 05:52 PM
Alex2.7T's Avatar
Im also thinking this happened to me because i had the camshaft locking bar installed on the camshaft pulleys, while I was installing the pin on crankshaft(which was really a pain in the ****) i was rocking it back and forth just a little, a few degrees right and left for easier insertion of pin into the engine. But im not sure if i removed bar from the camshaft pulleys while rocking the crankshaft.
If this is the case, can i align the marks again by installing the bar holder on pulleys while aligning the crankshaft with the socket.
Old 06-22-2016, 03:57 AM
AvantHater's Avatar
align crank with lock pin first with camshaft lock-bar off, then you can get the cam bar on.
make sure that the crank lock-pin is fully seated, turn crank back and forth a few degrees until the pin is all the way in. if your cam bar cant line up with the cams, then something may have been mis-timed the previous timing service... it should line up 'almost' perfectly if crankshaft is locked right.
Dudealicious
Q5/SQ5 MKI (8R) Discussion
55
07-03-2016 09:31 PM
bangernomics
43
04-27-2016 06:21 PM
SlideFox
20
04-22-2016 05:22 AM
gadgetcoma
04-09-2016 02:45 AM
Dr944S2
03-28-2016 07:54 AM
Quick Reply: Crankshaft is a little off the TDC mark, is that really bad?
