Definitive solution to repair cruise control module 5GA 004 397-16
Old 05-09-2014, 03:10 PM
  #51
flepke's Avatar
Default Fines
man, you just made me a happy man, thnx, also from my wife and little gril.
Brings down the nummer of speeiding tickets for sure.
Good start of my weekend
Old 02-07-2015, 04:50 AM
  #52
Pocilga Elias's Avatar
Default purple plug
Hi, thanks for this i take my module out to ser tgis but the solderings are fine but i ser a plug that Camé out of the module the is disconected...is purple inside....can anyone tell me where it Goes??
Old 03-27-2015, 07:20 AM
  #53
piwhy86's Avatar
Hey guys, I have a 2001 A6 2.7T with cruise control problem, so I wanted to try this repair as it seems like an easy fix.
Only problem is I cannot locate this cruise control module.
I took the glove box out and looked everywhere for it but couldn't find it.
Any chance one of you can explain me where it is, or even better post a picture of it?
Thanks for your help.
Old 04-11-2015, 12:39 PM
  #54
realmexyaudi's Avatar
Default cruise control
I have an 05 honda and i enjoy using CC on long trips. I also have a 98 audi a6 Q but i don't know how to use cruise control.
Pls hint me.
Thanks
Old 04-12-2015, 06:24 AM
  #55
georgeb944's Avatar
Pls hint me.
Thanks
Simple, read the owners manual for a description.
Old 04-14-2015, 11:42 AM
  #56
Prospeeder's Avatar
The definitive solution is send them to module masters for repair. I did on my A4 and A6 and they work great. I tried doing the soldering some pins, which has worked for other odd modules on some cars, this didn't work. When I sent it to module masters they said there are several reasons they stop working not just poor soldering joints, and they address them all, and replace a few components. So if soldering didnt work, send them to module masters, 65$ you know it will work.
Old 07-16-2015, 06:33 AM
  #57
dhoerl's Avatar
Thought I'd chime in again - I'm the author of this thread, and I just want to confirm that after almost 7 years since performing this fix, its still working!
UPDATE: 8/18 - still works!!!
Old 07-16-2015, 06:35 AM
  #58
dhoerl's Avatar
Get the Bentley's manual and it will tell you where it is. Or post a separate question in separate thread asking for the location, then if someone answers it make sure you update your post to reflect where.
Good luck!
Old 07-16-2015, 11:42 AM
  #59
Prospeeder's Avatar
Good luck!
His car is a drive by wire, there is no "module" its part of the engine computer logic. Only 99 and earlier cars with a throttle cable have the module.
Old 07-17-2015, 04:57 AM
  #60
CRuby's Avatar
Is there a common CC failure point for post 1999 models (w/o module)? My son's 2000 A6 hasn't been working for over a year, but I moved onto fixing other car stuff once I saw the CC module was not behind glove box, as indicated for the earlier models.
Quick Reply: Definitive solution to repair cruise control module 5GA 004 397-16
