ECU error
ECU error
I have an ECU Error in my gearbox (I had a person scan it with his scanner)
Engine keeps on trying to start but never ticks over..
Is there any way of resetting ECU or disabling ?
I need to car to start !!
1) Year, model, engine, transmission
2) Exactly what ECU error in the gearbox
3) Where are you located?
4) Do you have VCDS cable?
5) Do you have Bentley Manuals for your car?
1: 2004 Audi A6 3.0 FWD Multitronic CVT
2: A friend used his scanner, reported an error on ECU inside gearbox:
Notes :
Multitronic ECU + oil
+ gasket
+ casing bolts
+ ecu seal
+ coding
3: Melb, Australia
4: No can get one from shop
5: No
Notes :
+ gasket
+ casing bolts
+ ecu seal
+ coding
3: Melb, Australia
5: No
It doesnt know what gear its put itself it will keeping it from starting. The computer for the transmission is known to fail on these. The TCU is of course inside the transmission as part of the whole mechatronic valve body unit with range selector. Might as well replace the trans for as expensive the parts are new.
Wednesday,20,July,2016,19:02:41:05357
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006)
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 186450km-115854miles
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4B0 910 155 HW: 01J 927 156 JK
Component: V30 01J 3.0l 5V RdW 3120
Revision: 00000006 Serial number: 00000001052991
Coding: 0000001
Shop #: WSC 04940 001 00001
VCID: 5BBFBF2099316DE64B-5141
Subsystem 1 - Part No: 4B0 910 155
6 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
RPM: 768 /min
RPM: 0 /min
RPM: 0 /min
(no units): 38.0
Torque: 42.0 Nm
Temperature: 36.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 1
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Freeze Frame:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller
Freeze Frame:
18165 - Supply Voltage
P1757 - 000 - Open Circuit
Freeze Frame:
18161 - Tiptronic Switch (F189)
P1753 - 000 - Implausible Signal - Intermittent
Freeze Frame:
18031 - Powertrain Data Bus
P1623 - 000 - No Communication - Intermittent
Freeze Frame:
Ross-Tech: Home
75 76 77
Coding: 0000001
6 Faults Found:
18265 - Load Signal
Freeze Frame:
RPM: 768 /min
RPM: 0 /min
RPM: 0 /min
(no units): 38.0
Torque: 42.0 Nm
Temperature: 36.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 1
Freeze Frame:
Freeze Frame:
Freeze Frame:
Freeze Frame:
Freeze Frame:
From your error codes, it looks like you have a CAN-bus failure. I have attached two pdf files, one of the pertinent error codes for your transmission and one of the VCDS method of testing your CAN-bus.
Good luck...
Good luck...
