HID Fog light Problem
2001 a6 2.8
I'm having problems installing hid I'm able to connect everything except red and black wires and i can find detailed instructions for my am i not connection something right or do i need to connect straight to the ballast
Hard to tell from your post.
The actual HID bulb/socket is connected to the ballast, usually by a big fat two-conductor wire/cable.
Sometimes google is your friend..you should be able to google the manufacturer and part number or model number of your HID foglight kit.
I dunno why people bother with HID fog lights…they're down in the mud and blood and beer, they're too bright to be effective at anything other than ego-tripping, they're expensive, and essentially the same effect can be procured with a halogen high temp bulb. I have HID on my M3 and used some off-the-shelf halogen bulbs with a color temp that essentially matches the headlights.
If manufacturers really wanted effective fog lights for the North American market, they would set them up so they could be independently lit of the main service lights and they would be yellow. Ah, naah,
Normally the ballast is connected to your (switched) power source, red being negative and black being positive/ground.
It's possible but then your ballast is live all the time.
Just use the black and red wires from your existing kit and wire them to the black and red wires on your ballast. You might have to install some female terminals on the wires on your existing kit.
When you turn on the lights those wires will energize the ballast and your HID lights should go on.
I hate to be a jerk but this is simple. If you don't understand what to do in this situation you should probably pay someone to do it. Again sorry for the harsh words.
