how easy is it to replace coolant reservoir?
i need to replace my damn coolant reservoir. is that an easy self-install item? do i have to flush the cooling system also? thanks!
Take the engine cover off so you can see the hoses
by the firewall. More room to work. Clamp off the hoses if you can and have a container ready to catch all the fluid when you remove the bottom hose from the reservoir. Don't overtighten the hose connected to the plastic reservoir. I replaced the stock clamps with some small hose clamps that you can tighten with a screw driver.
The reservoir is pretty much the high point of the system. Suck out coolant w/ old turkey baster
or buy one at Walmart for $1. Couple hoses and a sensor plug. You'd have to try to spend more than 15 minutes on it. Be careful with the coolant, though as it can eat through the paint if you spill any on the finish. Wash off any spills with a lot of water and you'll be fine. It's not like acid, it's just if it sits on there it can soften and screw the finish.
Greg Burch
Audi A5 / S5 / RS 5 Coupe & Cabrio
01-19-2019 05:21 AM
Corey
10-11-2005 08:01 AM
zon
09-20-2002 02:06 PM
