Interior lights problem
Hi guys,
In my A6 from 2001 (Europe) with 2.5 v6 engine and Quattro (although that doesn't make a difference I guess?) only the interior lights from the front seats do work (with the switch, and with opening/closing the doors).
Above the back seat only the lights for reading work, the bigger central unit doesn't, and in the boot nothing works.
Regardless if there are any doors opened, and regardless of the position of the switches, I never get 12V on the sockets from the back seat/boot. For the boot I checked with and without headlights on, as that was supposed to make a difference with certain models? But no result.. All 4 door switches (the ones that let the car know if the door is open/closed) do work, I'm unsure about the boot switch but considering that the light switch itself makes no difference there and the doors don't make a difference for the back seat I don't think that's an issue here right now.
Something I find strange (but maybe isn't?) is that the lights for your feet at the back seat do work when opening a door.. Also the mini red lights in the switches that indicate where the switches in the roof are, all do work.
Is there somebody with an idea or (similar) experience? Any help is much appreciated!
Thanks in advance, Alwin
Just bumping this thread, I'm having the same issue on A8 2003 (D3)...
Also, the button for the rear blind does not work (the button is located above the back seat).
I have resolved my issue
(not the boot light - that one still doesn't work)
I'm a bit embarrassed to say that the "problem" was that the "child lock" button on the driver's door was enabled
When enabled, it has two (red and orange) 'window' icons on it.
I pressed it and my roof controls started working again
BTW, I first did "output tests" for the roof controls using VCDS, and I found out that the lights on the roof console were good (they were turning on and off during the tests).
boilermaker66
05-04-2010 01:04 PM
StarryTripper
16
01-24-2007 08:09 AM
The Devil
04-18-2004 02:32 PM
