oil leak, back of engine , 2003 A6 3.0
#11
I have a oil leak in teh back of the engine and I can;r see where it's coming from. I replaced the valve cover gaskets about a year ago,
not sure if those are leaking again or not. what typically leaks , what gaskets in the 3.0 engine?? are there cam gaskets or is that just in the 2.7 engine?
maybe I got cheap gaskets last time and they need replacing again.. I can't see anything to put my finger on it. just oil all over on the drivers side toward the back.
getting messy..
getting messy..
#12
No I haven't tried fixing the oil leak problem yet , I have a MG I drive in the summer so it hasn't been a problem, but I need to get back to it . Is there any pictures of the Ventilation valve? I'd like to try that since I know it hasn't been replaced yet. only the PCV has been replaced. also some pictures of the seals mentioned above would be nice, is there a part number for the venttilation valve ???
#14
The part number is 06C-103-245 Internet price of $145.83 with tax. I saved on the shipping by picking it up at the dealer. I got it from parts.audiofalexandria.com but you can have my slightly used valve for half that price, shipped! My Audi died on me, a small screw came loose on the back side of an intake camshaft pulley. It took out my timing belt, which took out my engine by bending the valves. It sucked.
Stan
#15
Started back looking at the oil leak in my 3.0 2003 A6, so I want to check the whole system to see if everything is clear and nothing is plugged, is there a diagram some place of what I have to look for ?? Ok the PCV valve I can check , I did replace it already but with a cheap one. what else do I need to look for ?? I can see the oil on the back and bottom of the engine but can;t see up there to see where it's coming from .. any pictures would help, I even bought a camera to see if that would help , everything is to close together back there.. do I just take off the hoses on the back of the valve covers and check them?
#16
I think I figured out the breather system is plugged going back to the oil pan. I'm getting moisture in the system and it doesn't have any place to go. So it look like have to remove the Manifold to clean out the system. Is there a write up on how to take the fuel injector apart , fuel rails etc. do I need any special tools? you can;t get your hand back there to do anything to clean it. I need to replace my coolant temp sensor anyway. I'll kill to birds. Is there a write up on how to take it off, it doesn't look like a big deal if you can get the bolts out. It's just the fuel rails I have to take off, I have no experience with those.. any help would be appreciated. I can spray cleaner in there and in a little while I see it on the ground. So something is happening. Never heard of this one but I know the breather system is important to the 3.0 engine..
#17
Buy the bentley manual or search on youtube.
#18
I did search you tube, found one video of some one taking the manifold off to replace the plastic water hoses underneath the manifold, Hope that doesn't happen to me. Most items were for the 2.8L engine. I hate spending $130 for something I use once. the car is getting old and I want one more winter out of it and it's down the road.. usually there is a write up some place I can use. these car are great to drive but have usual things go wrong with them. I hope it's not just the junkie PCV that was mentioned above in the thread..
#19
sounds like the 2.7t engine you have a seal that leaks at the end of the intake and exhaust cam on drivers side 1 under the hal sensor and a rubber cap on intake lower cam they leak after awhile and thats what i think your leaking from if i could see a pic i could tell you for sure.
#20
The 3.0 is nowhere the same to the 2.8, 2.7t or 4.2 regarding cam timing, adjusting/sensing or seals and gaskets.
