Rear brake light (one side) always on
Old 05-28-2012, 10:16 AM
GTA_Driver's Avatar
Default Rear brake light (one side) always on
Doing a search for a specific problem like this is an exercise in frustration.
My stop light (rear driver's side) light bulb burned out. Bought a generic bulb at local store (not dealer), put it in. Since I have the 01 Canadian A6, the lights are always on, including the rear lights.
The problem is that the driver's side tail light always glows as if the brake pedal was pressed. When I press the brakes, the right one lights up to match the left one in intensity, but when I release the pedal, only the right taillight dims.
Is this a bad bulb, or did I insert it incorrectly? Everything seems to have matched - the voltage, wattage, and even how I popped it into the housing.
Old 05-28-2012, 11:27 AM
SloopJohnB@mac.com's Avatar
sounds like a floating ground. With the lens assembly out of the car to make it easy, clip a grounded wire to the outside of the bulb socket in question. If the thing works, fix the ground.
OTOH, think horses rather than zebras. You might have the wrong bulb, or put it in wrong. Swap the bulbs left to right and see if the new bulb behaves the same way on the pax side.
Old 05-28-2012, 11:32 AM
ezveedub's Avatar
Make sure you used the correct bulb. Sounds like a single filament bulb in a double filament socket or vice versa.
Old 05-28-2012, 12:06 PM
GTA_Driver's Avatar
nope, a double filament bulb. I'll reseat it again today, and swap bulbs.
Old 05-28-2012, 12:12 PM
Just as easy to check/make a ground wire too.
kone
01-14-2019 03:10 PM
RGa6
09-15-2005 02:21 PM
NIJ
10-03-2004 04:15 PM
DaveManJam1
Audi 100 / A6 (C4 Platform)
06-10-2003 01:20 PM
Quick Reply: Rear brake light (one side) always on
