Red Oil Warning Pressure MFI symbol but oil level full
#21
ok i know this post is old as ****, and im sorry to bring it back. But the light he is talking is for the oil LEVEL, not pressure, right? im having the same light pop up, and when i hit the left button on my gauge cluster, it says shut off engine and check oil level. i just want to make sure im looking in the right direction to fix my problem. the red oil can dripping oil is an oil level issue and not a pressure issue. can somebody confirm this
#22
Best check your owner's manual.
#23
believe it or not i didn't even consider checking my owners manual, although i did look through my bently and didn't see a single mentioning of warning lights.. ill have to check that out when i get home. thanks
#26
You're not mentioning it, but do you experience this red-light problem intermittently?
If you do, you may well find that subsequently your revcounter will stop working at the same time, ABS warning lights may shine etc. I had this problem with my 2.8 A4 and the problem came from the ABS-processor; yes, you read correctly! It is amazing just how the computer systems are interlinked.....
I fortunately have a wizard in our area, that could repair the processor for me, instead of the spending MUCH money for new parts
#28
The big question is how did you know the ABS unit was goofing with the cluster module? That answer would be more informative and conclusive.
#29
ABS unit goofing with cluster
Apparently the condition worsens and I can support that, as it even started affecting my tiptronic box, which was taking longer to change up. The latter was a "seat of the pants" feeling though, as I couldn't prove it, with a non-functional rev counter. The Electronics Engineer (wizard) mentioned this to me afterwards, when we took my car for a test drive after repairs.
There are a series of very thin copper wires in the processor, which "fractures" one-by-one, hence the progressive list of faults. The wizard could repair my car's processor, but he reckons that it could get to a stage where the processor can only be replaced.....
Hope that helps a bit!
(All this happened a few years ago, so I really have to jog my mind!! I recall now that I followed up with a mechanic, who referred me to the wizard. He said that if my car's rev counter wasn't acting stupid as well, the cause of the problem was the instrument cluster and not the ABS processor! Strange that the ABS-system can become dysfunctional due to an instrument cluster problem hey, but I suppose that is what we have to live with, driving cars that cannot be mended with "steel wire and a pair of pliers"!)
#30
Unfortunately I cannot answer that one jcman, as that knowledge came from the wizard, who repaired it for me. The ABS & traction control lights were on all the time, but the red warning light came on intermittently and together with that, the rev counter would stop indicating.
Guys (and girls!),
Please accept my sincere apologies, as I might 've been leading you on a wild goose chase......
The red light on my car indicated faulty brake system, NOT oil pressure! I remember that the red light triggered me into thinking that it was faulty oil pressure and I only realised much later (to my embarrassment), that it indicated faulty brakes.
So sorry to have repeated that mistake!
turkey burger
05-24-2006 11:02 AM
I changed the oil on my fiancee's 98 Accord V6 today. Capacity=4.6Quarts. Guess how much came out???
markbradford
11-26-2003 08:15 AM
The Turtle
09-07-2002 07:05 PM
