Revving Engine to 3,000RPM, Brief Sound of Sharpening Knives,
#11
If your rotors (brake discs) and/or pads are worn out, its time to replace them - wether they be an issue or not. That is not "preventive measures", its just maintenance. A word of caution; Do proper diagnosis when fixing an issue with these cars. Just "throwing parts" at it, will get stupid expensive very quickly.
Your initial post say you rev while in parking position (I assume the car is standing still). This means whatever you're hearing is not coming from any part in or directly connected to the drivetrain - as those parts are not moving when the wheels aren't turning.
#12
The sound of sharpening knives was present around the wheel when I checked again last night. The sound doesn't always appear. For now, a good thing to do is replace the spark plugs / coils which were throwing misfires on two of the six cylinders. Also, Air Box and, possibly the PCV Valve needs to be changed, the engine sometimes sounds sluggish on the road.
#13
As expected, it's another noise and not your rotors, as they don't spin when in park. None of the other mentioned issues are related to your knife sharpening noise. Any engine rotational noise creators have nothing to do with any of the other issues that you bring up. If real, the noise you describe could be related to rubbing covers over the timing belt, idler, tensioner, or alignment or pulley issues with the accessory/fan belt, etc.
Since you keep addressing things not related to the initially reported noise, this could still be the knudden valve or maybe the muffler bearing, or maybe the new rotors were bad. We are trying to help, so I hope this is not BS.
#14
Thank you Johnkk, I tried to reproduce the sound again today, but couldn't hear it this time around; might had to do with prolonged idling.
How can I remove the cover over the timing belt to make sure there is nothing apart from the norm?
#15
arjun..arjun...arjun, The thread started with a potential brake issue based on a noise while parked, a noise from brakes happen 99% of the time when moving NOT BEING PARKED......PLEASE UNDERSTAND THIS!
If you checked the thickness of the rotor with a micrometer and they are at the WEAR LIMMIT change them along with the pads.
If your PARKED and the engine is making noise @3K RPM this has nothing and I MEAN NOTHING to do with brakes......PLEASE UNDERSTAND THIS!
#17
#18
Start with the accessible rotational parts driven by the serpentine(fan belt) and not the timing belt. Squirt some wd 40 on pulley shafts one at a time and if the noise disappears, you've found the squeaker. A stethoscope or long screwdriver against the ear touched to shafts or bolts that hold various pulleys and tensioners will pick up pulley bearing issues, but can be dangerous if you get caught in moving parts.
Depending on your engine, you might be able to unsnap some timing belt covers with out moving front assembly to the service position, but the water pump and tensioner evaluation would require service position. Learn how to "assume the position" before you dig in. STFA.
A4S424
A4 (B8 Platform) Discussion
03-20-2017 11:40 AM
Dimi (A6 2.7T)
11
02-29-2008 07:37 AM
Mr. Z
05-10-2006 08:46 PM
northerns4
11-17-2002 03:23 PM
