Rotor/brake/ locked wheel question
Hi guys,
I bought my 1999 Audi A6 Quattro used a few years back. I need to replace the front brakes but I need some help.
1) I have these wheels but they have locking lug nuts, and I was never given a key...Does anyone know anything know how i can get one or find out what type of nuts they are? The lug nuts are deep in the hole with very little room to stick anything in there. From what I can tell tell, they look splined?
2) Do I need to get different sized rotors or brake pads (I need both) because of these aftermarket wheels? From what I measured, they seem to be 17x7.5
Thanks
Thanks
Hi guys,
Thanks
Thanks
As far as what you need for rotor and pads, you need to look at the rotor and see. Audi is very good at throwing various sizes of rotors on their cars, even in the same year and model they can have different size rotor, typically they will be marked in close to the hub. I would bet pads will be the same size
A lot of tire shops have sets of locking lug sets that they can use to get the bolt off for you, just make sure you have replacements that you can drop in with you.
Thanks again
Wow..just wow. You've had the car for a few years and never removed the wheels?
Hi guys,
Thanks
Thanks
Good luck on getting the splined locking lug bolts out…find a good wheel shop first.
You could also go online and get a lug bolt removal kit. Google is your friend.
Brandsport Keys Master Wheel Lock / Lug Nut Keys w/Free Case
The key for those wheels should always be in the car. Maybe he forgot to mention it. Check the tool box(jack box, spare tire area). Otherwise when you get a flat you're screwed to begin with...
Jut to make sure, you're not talking about plastic caps that some C5's have over the log bolts for protection against rust?
You could also just drive on a 12point undersized socket
This often ruins the 12pt socket, BTW.
I would think that if your wheel locked up the issue would be in the caliper, pads, or the condition of either. It takes a lot of force to lock up a wheel at driving speeds, so I would look to the caliper first. A failed brakepad, shifting around, could also be the culprit.
bballfreak
9
04-14-2019 06:59 PM
alphanumeric818
05-25-2016 10:01 AM
Audi A6 2010 Audi A6 3.0T Quattro
lukasz.contractor
10-03-2015 10:04 AM
thechristina
10-03-2015 05:54 AM
