Too much transmission fluid.
The fluid will froth and you'd likely burn out your pump/clutches if it's a tip. If it's a manual the trans will puke fluid out of the vent on the top of the diff case.
Fill the trans on an incline or with the vehicle tilted to one side. With manuals its really easy to do if the car is on ramps, the fluid will go to the rear of the trans, so you put in another 1-2 quarts thinking it's low.
gregg117
19
07-07-2020 02:40 PM
A6George
Audi 100 / A6 (C4 Platform)
03-13-2008 07:13 AM
Jon-1.8t
01-18-2006 09:57 AM
summersr
02-28-2002 01:41 PM
2002, adding, car, case, danger, fluid, happen, miata, motorcycle, oil, put, symptoms, tranmission, transmission, vehicle
