Transmission Pan
#11
Okay thanks. It's the 5 speed automatic. I'm pretty sure it's steel now and besides like you said, your 2000 and 2002 were steel. I doubt they would switch the material of something so insignificant as the pan and then switch back the next year.
#13
Trans pan on my 00 was steel. Did the same thing. punched a fist size hole in it. Don't try to weld it, you may end up warping it, unless you have a very skilled welder.
depending on the size of the hole, I'd bet that most if not all of the fluid that's not in the torque converter came out. That's good, since you're removing the pan anyway.
#14
It's a very small hole you can't even see. I only knew it was leaking because of the fluid coming out of course. But visually inspecting it, can't see anything at all. It looks scratched, not bent.
#15
#18
#19
Use google
1998-2004 Audi A6 Quattro Automatic Transmission Pan - Bapmic 01V 321 359 B - - PartsGeek.com
http://www.ebay.com/itm/like/172093317325?lpid=82&chn=ps&ul_noapp=truehttp://www.ebay.com/itm/like/221925873056?lpid=82&chn=ps&ul_noapp=true
#20
Yeah...wonder how many of these parts 'fell off the truck.' Shrinkage at dealers or warehouses.
