weird noise from suspension while driving
So this morning when I reversed out of my driveway on my way to work I heard a loud noise like a metal scraping (nails on a chalkboard or old playground equipment?) I shift into drive and accelerate and the noise persisted and got louder the faster I went. I thought that I was about to burn my timing belt so I pulled over and didn't hear but any noise from the engine. I went ahead and drove back home (didn't go far at all) and while driving back I hit a small bump and the noise actually changed so that confirms that its suspension related. Transmission shifts fine engine is smooth and the car pulls nicely too and smooth except for the noise and there are no fluid leaks in that area. Its mostly coming from the front drivers wheel.
I am pulling front wheels off on saturday to poke around but mean while these things come to mind.
Control arms
Tie rod ends
Drive axle (outer boot does need attention)
Brake pad rubbing
Help
Thanks
2001 Audi A6 Avant 2.8 quattro 185,338 miles
Control arms
Tie rod ends
Brake pad rubbing
Help
Thanks
Brake pads. Most likely the rears. I would give it a check. If those pistons get too far out because of worn pads, and the the thinning of the disk, they fail to retract. It sounds like dragging metal on metal. Its worth a check. Emits a god awful sound.
brakes are new all around along with rotors (almost a year) I haven't had a chance to poke around yet but I did have a chance to creep the car slowly in my driveway and the noise is definitely coming from the front driver's side wheel. I have not driven the car anywhere meanwhile though. The 1/4 mile I did drive yesterday morning before turning around the car pulled nicely drove straight and smooth shifted smooth and braked normally nd smooth as well. I swear I hope I don't have to spend money and if I do that its not too much...
Could be a wheel bearing but is most likely a brake issue. Maybe a rock or mud got into the caliper. Wheels on our cars love to retain mud, snow, and rocks. Centrifugal force keeps it glued to the rim when driving but gravity makes it fall to the bottom when your car is sitting still.
I would agree with "the_duke" about debris dropping into the brake assembly. Jack it up and spin the wheel to localize the noise.
*UPDATE*
Anything is possible but probably not. Wheel bearing start making noise as the ***** break down. Noise is first heard when turning and as it continues to fail, noise is heard when traveling straight. Grab the spring or strut while spinning the wheel by hand. If the bearing is bad, you can feel the ***** grinding in the race.
NCSUHokie
12-04-2013 07:53 PM
BphuA400
04-29-2010 02:37 AM
Potomac2.7Tee
Audi 100 / A6 (C4 Platform)
11-20-2003 10:32 AM
