A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Seriously. Somebody Help.. Temp Sensor Question
Old 05-19-2013, 10:27 AM
itsgoodz's Avatar
Default Seriously. Somebody Help.. Temp Sensor Question
Ok Listen, I have a 2005 Audi A6/C6 3.2L. I am trying to change my coolant temp sensor. I cannot locate it for the life of me and reading all these post have confused me. Im hearing theres a blue and a green one?!? Heres what I purchased.
Now the issue is, I located what seems to be the coolant temp sensor, however Im hearing that there are two. I dont want to remove the wrong one and waste my time. But the one i located is pointed out in the picture.
SOOO.. Am I in the right place? for the 4-pin Green Coolant Temp Sensor? Please Help.
Old 05-19-2013, 10:59 AM
SchwarzS6's Avatar
What you are pointing at looks like it only has two wires. Remove the connector and check. I looked in the parts catalog and the part you are point at is listed as 06A919501 2-pin temperature sender. I am unable to locate a 4-pin temperature sender on the 3.2. Do you know the Audi part number of the sender you purchased?
Old 05-19-2013, 11:21 AM
itsgoodz's Avatar
Thanks for the quick reply. The part i purchased is not an Audi product its the BWD brand. it says BWD WT5129.
Old 05-19-2013, 01:06 PM
SchwarzS6's Avatar
Hmm. I am not positive, but my guess is that this is the wrong part. You probably should return it and purchase from an Audi dealer such as genuineaudiparts.com. This part is only $25 and if you give them your VIN and tell them what you want you will be sure to get the correct part.
Old 05-19-2013, 03:29 PM
itsgoodz's Avatar
Yeah, I think your right about me having the wrong part. I figured i could buy it quick and install it quick, guess i'll have to swing by the Audi dealership or order from the site you suggested.
Thanks alot for answering.
Old 05-19-2013, 03:32 PM
audia6s's Avatar
Only one temp sensor as per ondeman5. Look few threads below yours: https://www.audiworld.com/forums/sho...1#post24444141
Virkailija
16
04-06-2022 09:57 AM
eldoj
05-07-2007 09:55 AM
Arcteryx::Stock Rods
07-28-2004 07:59 PM
Ghostfire
06-11-2004 03:31 PM
Broker
01-13-2004 12:03 PM
Quick Reply: Seriously. Somebody Help.. Temp Sensor Question
