Run car without SC for a while?
Hi guys,
My SC makes a really bad noise for maybe 30 minutes when car starts, once it warms up it will quit down. I am guessing bearing or something mechanical in there and my mech took the belt out and noise went away. I want to buy another one but here in Europe it's a bit harder to find a good one, I am on vacantion can I run the car without the SC belt for a 2000-3000KM ?
Would it do more damage and what that could be ? I know there will be powerloss but how much really at the end of the day it's still a 3L engine.
Would the SC block the airflow or will the bypass kick in and work without a SC ?
Thank you,
Thank you,
Id first start by checking the oil in the SC.
Basically pull the SC (pretty quick only 6 nuts and a few hoses)
undo the allen key,
pour the oil out into a glass jar (about 150ml or so of oil)
mark the level on the jar,
refill with clean oil
reinstall SC.
See if that at least helps.
undo the allen key,
reinstall SC.
jonah
12-22-2006 10:23 PM
zero
04-22-2004 07:07 AM
