Last edit by: IB Advertising
- Audi MMI Problem Diagnostics<br>Guide to diagnose trouble and recommended solutions.
2008 Audi A6 MMI not working
[SOLVED] 2008 Audi A6 MMI not working
Hello. I have a problem with MMI 2G that I'm trying to solve for about a month now. It was working fine until it it just turned off (it was raining these days). When I press the volume button (mute), MMI screen comes on and then it says:
"Note: An installed component is not valid. Please contact an Audi Workshop"
MMI buttons are not lighting. I checked fuses in dashboard (drivers side) and in trunk multiple times and they are fine..
Car is a sedan.
VCDS Auto Scan:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F5 910 401 S HW: 4F0 907 401 C
Component: 2.7L V6TDI G000CG 0020
Revision: --H05--- Serial number:
Coding: 0011382
Shop #: WSC 02145 785 00200
VCID: 317002073129AF8AA08ECB9-8064
1 Fault Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 312955 km
Time Indication: 0
Date: 2015.08.02
Time: 15:53:42
Freeze Frame:
RPM: 756 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 22.1 %
Temperature: 25.2°C
Readiness: 0 0 0 0 0
Address 07: Control Head
Cannot be reached
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0WRY7F
Coding: 0013362
Shop #: WSC 02325 785 00200
VCID: 2940EA6719F9D74A68FE139-807C
Subsystem 1 - Serial number: 6332CSME36741A0F7
Subsystem 2 - Serial number: 6342CSME367356260
Subsystem 3 - Serial number: 6352QSME5B4C2757U
Subsystem 4 - Serial number: 6362QSME562C4537M
Subsystem 5 - Serial number: 63734SME4E0F3C4DN
Subsystem 6 - Serial number: 63834SME307A17490
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08215829A
Coding: F5519E7730120600
VCID: 2D481E772D11CB6A84A6279-8078
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 38
Mileage: 318764 km
Time Indication: 0
Date: 2015.10.22
Time: 17:39:25
Address 47: Sound System
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000031699
Shop #: WSC 00146 219 51406
VCID: 245EFB537EDB0A225B085A5-8070
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2802220891
Coding: 344630393135313035442056413032383032323230383931
Shop #: WSC 00000 512 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 15:46:09
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 15:52:35
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 16:08:03
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 16:08:13
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 23
Reset counter: 107
Mileage: 318779 km
Time Indication: 0
Date: 2015.10.23
Time: 03:52:58
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0000042
Shop #: WSC 02327 785 00200
VCID: 2E4A197B2017B072BDAC28D-807A
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 57
Mileage: 319778 km
Time Indication: 0
Date: 2015.11.01
Time: 19:53:55
Address 77: Telephone
Cannot be reached
Optical Bus Diagnostic
Controller Electrical Optical
19-CAN Gateway ERROR ERROR
07-Control Head ERROR ERROR
0E-Media Player 1 ERROR ERROR
77-Telephone ERROR ERROR
47-Sound System ERROR ERROR
56-Radio ERROR ERROR
(same results with Standard and 3dB Attenuation)
I was thinking about trying bypassing MOST but i don't know if its even problem in MOST since all these both electrical and optical errors from diagnostic.
Thanks for any help.
Car is a sedan.
VCDS Auto Scan:
Coding: 0011382
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 312955 km
Time Indication: 0
Date: 2015.08.02
Time: 15:53:42
Freeze Frame:
RPM: 756 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 22.1 %
Temperature: 25.2°C
Cannot be reached
Cannot be reached
Coding: 0013362
1 Fault Found:
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 38
Mileage: 318764 km
Time Indication: 0
Date: 2015.10.22
Time: 17:39:25
Cannot be reached
Address 56: Radio
Cannot be reached
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 15:46:09
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 15:52:35
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 16:08:03
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 306759 km
Time Indication: 0
Date: 2014.11.07
Time: 16:08:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 23
Reset counter: 107
Mileage: 318779 km
Time Indication: 0
Date: 2015.10.23
Time: 03:52:58
Coding: 0000042
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 57
Mileage: 319778 km
Time Indication: 0
Date: 2015.11.01
Time: 19:53:55
Cannot be reached
considering the number of faults you have related to aspects of your MMI and you pointed out that "it was raining these days", have you checked whether your BT module is operational?
You'll need to remove the driver's side seat and it's located under the carpet there...if it's slightly damp, you have clogged drains and there are some great DIYs on this forum. Leverage the SEARCH function on the forum and you will find plenty of info on this topic.
Thanks for reply, how can I check BT module if it's operational? With VCDS I can't since it's not reachable.
I don't have sunroof, could it be clogged drains ? I'll check the carpet tomorrow.
Thanks.
Thanks.
You may not have sunroof drains, but you have plenty of other areas where water can get in:
seals around the door frames
window seals
drain holes in front of the car
Under the driver seat, there is a black plastic square cap. This cap hide all the wire for your seat. Remove it and put your finger down around the connector. Try to go as deep as you can. If you feel water or moisture, your bluethoot module is probably fry. But as raj said the best way to know it, is to get the bypass and use it on every module. There is a lot of hole where water can come into your car... And get yourself a real vcds if you want real result. It going to pay for itself on the long run...
Carpet area under driver seat is dry, I removed the black plastic square cap with wires and I don't feel any water or moisture. However I'm going to order bypass cable and try it with BT module and other modules. Also in trunk, only the right side is removable and there is only Comfort ECU and antenna amp. Since I don't have Nav, I think they permanently attached (glued) the left side of carpet with tuner amp and other modules or where else these modules could be?
Thanks.
Right side (no MOST cables)
Left side (glued carpet)
Thanks.
A little update, it was the Bluetooth Telephone module.. I didn't want to remove pillars because I was afraid of breaking them so I just cut the carpet just enough to open the black box (I know it wasn't the best solution but you can't even see the cut and you have quick access to BT module at least).. Today wasn't even raining and a little bit of water and moisture was around the box!
If anybody is having same problem, module is not right under the seat but rather in front left side (leg area).
Thanks for help!
Thanks for help!
Thanks for help!
Thanks for help!
Thanks for help!
Thanks for help!
A couple of questions:
- can you reach the BT module without removing the driver seat?
- can I just remove the BT module to fix? Or do I first need to order a “MOST bypass”?
