3.2l timing chain replacement avoidable?
#11
I understand the draining down of the oil after letting the car sit overnight or longer. That is why there is an oil check valve in upper part of the block to keep that from happening. As LarryJa notes, proper maintenance can/should extend the life of the tensioner. However, if the design of the check valve and oil passages has reliability issues, then there is the potential for lack of oil to the upper tensioners. In a number of postings, it appears that the driver's side tensioner fails more often than the passenger side, which indicates a design problem to me (as a licensed mechanical engineer). But I believe Audi proved the chain driven camshaft design in their racing engines before they introduced them into production engines.
So, my position is as before - they should last as long as the other critical rotating engine parts, assuming the maintenance specified by Audi AG is strictly adhered to.
#12
Actually, I'm leaning toward it being a poor material choice for guides. Apparently, the plastic chosen for the guides is not durable enough for it's job.
In Ross Tech vcds,the engine module measuring block #93 provides the deviation, from ideal, for each of the four cams. You sum the readings of both cams in each bank. The readings are in degrees & the acceptable service limit is 8 degrees for each bank.
That should get you a start. :-)
#13
I drive a 2006 Audi A6 3.2 Quattro and am having issues with the bank 1 tensioners. Running rough but only intermittently. Dealer said I needed "timing chain and adjuster replacement" at a cost of 11,000.00. I declined and drove the car home, and it ran like new. Does this repair require removal of the engine? It has 156,000 miles, and I've had it serviced at the dealership since I bought the car new in 2006. Any suggestions?
#14
using 0w40 oil instead of 5w40 in cold climates also should be helful.
#15
if the value is far off (i.e. more then 6 degrees) you can try to replace the upper tensioners and see if that fixes the issue. The upper tentioner should cost less 2k between the parts and the labor.
I do not really see a point in replacing the chain for 11k since you can replace the whole engine with a used low milage for a half that price.
#16
Yesterday, I had to change my engine-driven hpfp. When I pulled the old pump, I found the cam follower for it barely, if at all, worn.
My '06 3.2fsi engine has 191k miles on it.
My block 93 readings have been steady, at 3.0 & 6.0, for the 40k miles that I've owned this car.
I'd say that's a reaffirmation of the 5k oil changes I've been doing with VAG approved 0w40 synthetic oil.
When I 1st bought this car, I also bought the cam lock tool set, for the "inevitable" upper timing chain tensioner change out. It looks like I may never need them to hit my 250k mile target.
Oil maintenance is recognized as typically the most critical factor in engine life.
We'll see....
We'll see....
#17
Timing Chain Tensioner - 2010 Q5
Hi everyone,
I am new to Audiworld, but have been a loyal Audi owner for over 20 years, but unfortunately that may change.
Yesterday, I was informed by my Audi Service Department that my 2010 Q5 that has 51,000 miles on it will need major work. They told me the timing chain tensioner was stretched which caused problems with the camshaft, ultimately the interior of the engine. I am in total shock, since they quoted me $13,500 dollars. As you would expect, I am still in shock. I have never missed an oil change, service or recall notification. My car was running fine, and to me this is a manufacturer defect not something that could of ever been done at this low of miles. I called the attorney that is handling the Class Action Lawsuit regarding this, and he said that the case is not guaranteed. Therefore, is there anything anybody can do? This is such a dilemma for me, I loved my car but I have 2 small children and wondering if ever putting them back into this car, let alone paying that stupid money. Any advice would be great
#18
vagcom measuring blocks , code 93 review
I was the original owner of a 2005. I changed the oil every 5,000 miles and was meticulous with having it serviced at the dealer. Despite this care, the tensioners and the guides failed around 135k miles. These parts are made out of plastic and have a limited life expectancy. By the way, at 135k miles the chain had zero stretch.
my Vag-com numbers are :
code 93—2.6kw,,,6.8 kw,,,,3.0 kw,,,4.5 kw
Thank you !
#19
#20
It is beyond any sort of reality that this chain tensioner would stretch (fail) at 51,000 miles. I am beyond livid at Audi for this failure. I sent a complaint to Audi of America waiting now to see what they will do. To me, this is a MFR defect
