Audi A6 2006 3.2 Quattro Transmission Replace
Hi friends! After several attempts to fix my transmission on my A6 3.2 quattro(replace to oil,filter,check the oil) I finally decide to replace it with a used one . I will start to take mine down today and then i will order the other one after..Any suggestions or advise for remove the transmission? Do I need to reprogram the used transmission that i want to install on my car? Thank you and will wait for some tips.
I pulled a trans to do the timing chains. Surprisingly easy. No subframe interference at all. Leave the center driveshaft in the car.
The hardest part will be supporting the trans. Are you working on the ground? What is your plan?
On the ground
On the ground .I have 2 big hydraulic jacks , I will lift the car in the air as much as I can..and i will support the jack with one Jack and try to take every bolt down
Ohio-Maine-Boy
Suspension Tuning Discussion
04-30-2012 08:01 AM
