Audi Newbie - 06 a6 Steering Wheel Audio Functions Not Functioning
Hi All,
I've been Googling furiously for an answer to this one (and a few other issues which I'll post separately for the sake of operational prudence), but I having really found a solution. I purchased a 2006 Audi a6 (4.2 L Quattro) a few days ago, and one of the issues is that the steering wheel audio controls are not working. The backlight is functional, wheel telescoping and height set are functional. I don't know about the horn yet, but I live in Atlanta, so I'm sure I'll know soon. Is this a major issue? I read somewhere about needing to teach the radio through VAG-COM, which is somewhat expensive. Are there any other things to check? Is VAG-COM the way to go?
Some background: The broker I bought it from said he took it to Audi, had MMI and Nav updated and had them repair a few other things, like a leaking coolant reservoir.
Thanks, everyone!
Thanks, everyone!
Hi All,
Thanks, everyone!
Thanks, everyone!
Well the first thing I would have done buying ANY Audi would be to request a full Vag-com (VCDS) log. There's no "programing the radio" and without you have the log available for us to help you with, we have no idea the state of the issue. It could be as minor as a fuse or ???
Any self respecting Audi owner should own a VCDS, imho...it just makes life so much easier from a troubleshooting perspective. If you are not up for buying such a usefull tool, then have a good friend who has one and agree to buy them an alcoholic beverage or 3 for the ability to use it
Hi Mike,
Thanks!
I was finally able to get a VCDS on the car to read all the codes. Here's everything but the engine, which is having it's own set of issues.
Like I said, I'm new to Audi, and really starting to wonder if I made a mistake buying one. And I hate saying that, because it's beautiful.
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 4,2 MPI USA 0020
Revision: --H01--- Serial number: 4037879
Coding: 0000002
Shop #: WSC 02327 785 00200
VCID: 326BEAECADBD09AE9B-8066
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 C HW: 4F0 614 517 C
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021352
VCID: 24471CB4E749971E19-8070
3 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 178
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 12:09:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x002D
Hex Value: 0x0594
Hex Value: 0x00FF
02083 - Message for Delay Request
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x002B
Hex Value: 0x0591
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 198
Mileage: 192321 km
Time Indication: 0
Date: 2005.02.01
Time: 12:09:25
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x0191
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0180
Revision: 30070501 Serial number: 10600300182101
Coding: 0000015
Shop #: WSC 09416 444 57312
VCID: 63C55FA8A2C7D02620-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H26 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H44 0060
3 Faults Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 192102 km
Time Indication: 0
Date: 2016.03.11
Time: 21:40:46
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 201
Mileage: 192237 km
Time Indication: 0
Date: 2016.03.14
Time: 04:09:30
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303KG057513042
Coding: 0000003
Shop #: WSC 29422 001 1048576
VCID: 3169E5E0A8BB32B6E2-8064
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000169116
Subsystem 3 - Serial number: 0131.05.050000000100011302ÿ
Subsystem 4 - Serial number: 011302ÿ
1 Fault Found:
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 197
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 16:34:40
Freeze Frame:
Bin. Bits: 00010000
Bin. Bits: 0000000
Bin. Bits: 000
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030024998
Coding: 0008232
VCID: 5BB567489AB7E8E668-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 A HW: 4F0 907 279 A
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0113123
Shop #: WSC 02335 785 00200
VCID: 275D0BB8967F7C063C-8072
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:00
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 21
Reset counter: 166
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:34:00
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:00
01494 - Bulb for Parking Lamps; Left (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:34:00
01498 - Bulb for Parking Lamps; Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 197
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:34:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7175250
Shop #: WSC 00000 000 00000
VCID: 1C372454DF39AFDEA1-8048
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 2
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 16:19:59
Freeze Frame:
Text: 00006210
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7E5007466
VCID: 285F08849B61737E35-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 136
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 10:30:02
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH01 0020
Revision: -------- Serial number: 00000000000000
Coding: 0011118
VCID: 23451FA8E247902660-8076
3 Faults Found:
02002 - Heater for Distance Regulation Sensor (Z47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 140
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 10:30:06
Freeze Frame:
Temperature: 15.0°C
Voltage: 13.95 V
Bin. Bits: 01010
Hex Value: 0x2A11
Hex Value: 0x0002
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 10:30:06
Freeze Frame:
Temperature: 15.0°C
Voltage: 13.95 V
Bin. Bits: 01010
Hex Value: 0x2AE1
Hex Value: 0x0003
Speed: 0.0 km/h
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 192321 km
Time Indication: 0
Date: 2005.02.01
Time: 12:09:24
Freeze Frame:
Temperature: 20.0°C
Voltage: 10.88 V
Bin. Bits: 01010
Hex Value: 0x2513
Hex Value: 0x0002
Speed: 0.0 km/h
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 67 AIRBAG AUDI8RH29 0260
Revision: 11H29000 Serial number: 00359D090ZA+
Coding: 0013879
VCID: 2A5BF28C856D416E23-807E
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME3E357A75F
Subsystem 3 - Serial number: 6342CSME0A124C3F9
Subsystem 4 - Serial number: 6352QSME020118470
Subsystem 5 - Serial number: 6362QSME02031D0FC
Subsystem 6 - Serial number: 63734SME0512290FZ
Subsystem 7 - Serial number: 63834SME0144322DV
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0310
Revision: 00H01000 Serial number: 90026051440597
Coding: 0012251
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 K
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4R154DT55
Coding: 2257263
Shop #: WSC 09416 444 177977
VCID: 214915A0F85B823672-8074
1 Fault Found:
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:44
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 E
Component: Gateway H10 0060
Revision: 10 Serial number: 11009053110077
Coding: EEFE73CD1B7904
Shop #: WSC 02325 785 00200
1 Fault Found:
02001 - Data-Bus Automatic Distance Regulation
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:45
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 61C955A0B8DBC23632-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H44 0740
Revision: 00000000 Serial number: 355FZ057547835
VCID: 387FD8C44BC1E3FEA5-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0051947
VCID: 29590D80806B4A762A-807C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01004574620000
Coding: 4619325
VCID: 2E53FE9CB9852D4EFF-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 166
Mileage: 190469 km
Time Indication: 0
Date: 2005.02.24
Time: 12:47:03
02742 - Bulb for Brake/Turn Signal Light; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 21
Reset counter: 196
Mileage: 191890 km
Time Indication: 0
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000788036
Coding: 0000026
VCID: 254101B0EC736E160E-8070
1 Fault Found:
02457 - Loudspeaker in Hat Shelf (R150)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 113
Reset counter: 206
Mileage: 192319 km
Time Indication: 0
Date: 2016.03.27
Time: 11:33:42
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000001446
Coding: 0012114
VCID: 5EB36E5C89A5FDCE0F-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.15
Time: 20:32:00
Freeze Frame:
Voltage: 15.600 V
Temperature: 40.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0006022
Shop #: WSC 02334 785 00200
VCID: 5DB1695084A3E6D616-8008
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 264306BC9175650E07-8072
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02071 - Local Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394FX057553860
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000043539
Shop #: WSC 09416 444 58594
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 5856857534
Coding: 344630393135313035442056413035383536383537353334
Shop #: WSC 43772 000 1048576
3 Faults Found:
02252 - Generator
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 7
Reset counter: 196
Mileage: 192285 km
Time Indication: 0
Date: 2016.03.15
Time: 15:15:05
02252 - Generator
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00110011
Fault Priority: 1
Fault Frequency: 7
Reset counter: 196
Mileage: 192285 km
Time Indication: 0
Date: 2016.03.15
Time: 15:15:10
02479 - Partial Consumer Shut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 192285 km
Time Indication: 0
Date: 2016.03.15
Time: 15:15:17
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0051754
VCID: 69D94D8040EB8A76EA-803C
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000700006331
Coding: 0062422
VCID: 60CF50A4B3D1CB3E3D-8034
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000506020257
Shop #: WSC 12336 024 394758
VCID: 3467ECF457A9079E89-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0020
Revision: 00H09000 Serial number: 11720513004467
Coding: 0001206
Shop #: WSC 131071 1023 2097151
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 198
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 16:33:28
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 1130
Revision: 00000000 Serial number: 00000007501496
Coding: 0010900
End-------------------------(Elapsed Time: 02:56)--------------------------
Coding: 0000002
Coding: 0021352
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 178
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 12:09:55
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x002D
Hex Value: 0x0594
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x002B
Hex Value: 0x0591
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 198
Mileage: 192321 km
Time Indication: 0
Date: 2005.02.01
Time: 12:09:25
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x0191
Hex Value: 0x00FF
Coding: 0000015
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 192102 km
Time Indication: 0
Date: 2016.03.11
Time: 21:40:46
00955 - Key 1
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 201
Mileage: 192237 km
Time Indication: 0
Date: 2016.03.14
Time: 04:09:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 197
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 16:34:40
Freeze Frame:
Bin. Bits: 00010000
Bin. Bits: 0000000
Bin. Bits: 000
Coding: 0008232
Coding: 0113123
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 166
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:34:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:34:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 197
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.26
Time: 13:34:00
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 16:19:59
Freeze Frame:
Text: 00006210
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 136
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 10:30:02
Coding: 0011118
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 140
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 10:30:06
Freeze Frame:
Temperature: 15.0°C
Voltage: 13.95 V
Bin. Bits: 01010
Hex Value: 0x2A11
Hex Value: 0x0002
Speed: 0.0 km/h
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 10:30:06
Freeze Frame:
Temperature: 15.0°C
Voltage: 13.95 V
Bin. Bits: 01010
Hex Value: 0x2AE1
Hex Value: 0x0003
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 192321 km
Time Indication: 0
Date: 2005.02.01
Time: 12:09:24
Freeze Frame:
Temperature: 20.0°C
Voltage: 10.88 V
Bin. Bits: 01010
Hex Value: 0x2513
Hex Value: 0x0002
Speed: 0.0 km/h
Coding: 0013879
Coding: 0012251
Coding: 2257263
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:44
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 196
Mileage: 192287 km
Time Indication: 0
Date: 2016.03.26
Time: 13:08:45
Coding: 0082954
Revision: 00-00000
Coding: 0051947
Coding: 4619325
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 166
Mileage: 190469 km
Time Indication: 0
Date: 2005.02.24
Time: 12:47:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 196
Mileage: 191890 km
Time Indication: 0
Coding: 0000026
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 206
Mileage: 192319 km
Time Indication: 0
Date: 2016.03.27
Time: 11:33:42
Coding: 0012114
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 192284 km
Time Indication: 0
Date: 2016.03.15
Time: 20:32:00
Freeze Frame:
Voltage: 15.600 V
Temperature: 40.0°C
Revision: 00-00000
Coding: 0051947
Revision: C63C0030
Coding: 0006022
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Coding: 0000002
3 Faults Found:
02252 - Generator
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 196
Mileage: 192285 km
Time Indication: 0
Date: 2016.03.15
Time: 15:15:05
02252 - Generator
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 196
Mileage: 192285 km
Time Indication: 0
Date: 2016.03.15
Time: 15:15:10
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 192285 km
Time Indication: 0
Date: 2016.03.15
Time: 15:15:17
Coding: 0051754
Coding: 0062422
Coding: 0051754
Coding: 0001206
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 198
Mileage: 191878 km
Time Indication: 0
Date: 2016.02.04
Time: 16:33:28
Coding: 0010900
Got a feeling the issue is related to: 02244 - Button in Control Head is Stuck
It might be an issue where you need to remove the MMI unit and clean it with isopropyl or it could be something else...you'll need to use the search and do some due diligence, but at least you can start some troubleshooting.
On another note, that's a lot of electrical problems. Some times a new battery will fix those, but since you just got the car, do you think it might be a salvage title that had a water issue?
Yes, I was referring the MMI controller in the center console...clean it well. There is a good write-up on how to remove it and then you can really get in there and ensure it's clean of debris and gunked on spilled caffeinated beverages
I believe he means the panel in the center console with the buttons to control the MMI.
Since I bought it, I did buy a new battery for it, and it was only disconnected for about 15 minutes. From my research, it sounds like I need to disconnect it for 3 hours or more to reset the voltage regulator. I'll do that this weekend and then borrow my buddy's vag-com again.
I verified beforehand and still have the CarFax. It is a standard, clean title and is absolutely not a flood car. It is, however, 10 years old.
Thanks, all.
Thanks, I'll check that. But it's surprising that would negatively affect the steering wheel. I want to replace the big button/wheel anyhow because the top isn't smooth anymore, so I'll just dig deeper when I do that.
Thanks, all.
Thanks, all.
Including the fact that you should clear all codes from each module (individually) and take care of those that come right back after a short Drive.
Carr04Avant
04-14-2016 03:00 PM
Apocalypso
01-28-2011 08:56 PM
Aces
12-18-2004 01:37 PM
