A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
blower/Climatronic won't work
Old 06-16-2016, 11:13 PM
snibbe's Avatar
Default blower/Climatronic won't work
hi got a problem with the climatronic the blower won't work i did test it with a 12v battery and it runs fine, Then i thought it was the resistor but no it was not. i got these fault codes of my delphi cdp
02071 Fault in Circuit
, local databus
permanent
00256 - A/C Pressure/Temperature Sensor
Old 06-20-2016, 09:21 AM
turbo97se's Avatar
We had a similar problem before. The climate control would periodically turn itself off. It would work for a while and then decide to turn itself off. When I scanned it, I got an error. When I took the blower motor out, it seemed to work but not completely smooth. I took it apart, cleaned off some build up and added silicone spray (if I recall correctly) to the motor shaft. Put it all back together and voila ... no issues for about 3-4 years now.
Old 06-21-2016, 03:51 PM
quan717's Avatar
I had the same problem, I open the hood, remove the cowl cover to expose the plastic housing that houses the blower. turn the car on with blower on high, go back under the hood and fist hammer the housing , and Voila! blower works and hasn't had problem for 2 months now.
Old 06-21-2016, 09:26 PM
raj99's Avatar
I guess you and the Fonz have the same luck with your hands
Old 06-22-2016, 10:22 AM
turbo97se's Avatar
LOL .. Perfectamundo!
Old 06-22-2016, 07:06 PM
quan717's Avatar
ahhaa! hey, what ever works right?
Old 07-25-2016, 06:07 AM
snibbe's Avatar
fault has been solved,
4F0 820 511 A Climate control flap positioning motor
and the
A/C Pressure sensor was also broken.
schiu
11
12-27-2019 01:10 AM
hunterp27
61
08-13-2016 06:30 PM
PAB
04-07-2016 02:35 AM
MartinCB
04-06-2016 04:55 AM
nsupple1
Audi A3 / S3 / RS 3
03-24-2016 07:42 AM
Quick Reply: blower/Climatronic won't work
