A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Cam position sensor
Old 08-22-2014, 04:49 AM
Robert Schirmer's Avatar
Default Cam position sensor
Hi Guys,
Anyone know which head this is for and is it the one on the top or bottom cam? Had this code a couple of times this winter and it went away but it is not going away this time.
Thanks,
Bob
r Order:
Address 01: Engine Labels: 06E-910-559-BKH.lbl
Control Module Part Number: 4F2 910 559 B HW: 4F1 907 559 A
Component and/or Version: 3.2l V6 FSI 0030
Software Coding: 01050109190F0120
Work Shop Code: WSC 09222 444 58773
VCID: 2B5E06B68AC775461E5-807E
2 Faults Found:
000033 - Bank 2: Camshaft A (Intake)
P0021 - 008 - Retard Setpoint not Reached (Over-Advanced)
Freeze Frame:
Fault Status: 00001000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 220283 km
Time Indication: 0
Date: 2014.08.16
Time: 13:39:39
Freeze Frame:
RPM: 2336 /min
Mass Air / Rev.: 179.9 mg/str
Temperature: 91.5°C
Part Throttle
Bin. Bits: 00000000
Steering Angle: 86.01°
000838 - Camshaft Position Sensor (G163)
P0346 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 4
Fault Frequency: 8
Reset counter: 40
Mileage: 220292 km
Time Indication: 0
Date: 2014.08.16
Time: 14:59:02
Freeze Frame:
RPM: 832 /min
Temperature: 42.0°C
Idle
Bin. Bits: 00010000
Speed: 0.0 km/h
Readiness: 0000 000
Old 08-22-2014, 06:48 AM
hrc4u's Avatar
seems to be upper (intake sensor) driver side..
cheers!/H
Old 08-22-2014, 09:09 AM
cheers!/H
Thanks! Will post if it goes away tomorrow.
Bob
Old 08-22-2014, 09:42 AM
mrlexl's Avatar
Audi cam position - Automotive Service Professional
Old 08-22-2014, 10:07 AM
mrlexl's Avatar
It's your problem.
Old 08-22-2014, 10:10 AM
mrlexl's Avatar
See position N 2.
Old 08-23-2014, 05:43 PM
I tied the sensor in the two different intake positions and no luck. I am going to try the hydraulic valve as pictured above next. After doing some research, it looks like that may do it. I am going to "shock" the valve first to see if it comes loose.
Bob
Old 08-24-2014, 08:10 AM
roylok's Avatar
I had "P0019 CMP Sens 4 (G301) / Engine Speed Sensor (G28) " twice when scanning the car without ever seeing MIL. Than I had the solenoids getting lazy and related "retarded" error codes and misfires. Seems like a Camshaft solenoid valve can give position sensor error as well. Shocking the valve is only a temporary fix. There is a design flaw with the filter mesh that breaks off and clogs the valve. The pic of the valve above is of my intake valve, I cleaned it, shocked it and it lasted for about a week than it was completely dead. I replaced it with a new one than I had the exhaust solenoid jammed as well
I replaced the solenoid, and the passenger side solenoids, if two can go bad within a month or so I wasn't going to wait for the other two to go bad and leave me stranded somewhere or damage the engine.
On the bright side if it's just the position sensor, it's very easy to replace and cheaper than the solenoids. About $20 each. Bank 2 is driver side, intake on top of the engine , exhaust is lower on the side.
All four solenoids have the same part number, and so do the position sensors.
Old 08-24-2014, 02:04 PM
How shocking, it didn't work! I did get the spring dislodged but the valve still hangs up. Off to the dealer Monday for a new one. Nothing ventured/nothing gained>
Bob
Old 08-25-2014, 08:30 AM
Well the solenoid did the trick. 400 mile road test today to confirm but a short drive and re-scan showed up no error codes and yesterday it did. Wish me luck!!
Thanks,
Bob
Quick Reply: Cam position sensor
