checked esp fuse/amp on drivers side and now anti-slip light stays on
I was checking fuses on my fuse box and came across the esp fuse/amp and it was fine so i put back in properly and now the yellow antislip light with the vehicle symbol stays on. Only reason as to why i got curious and checked was cause in the past i had an issue with my esp fault and had this fixed so i just wanted to make sure my fuse was never an issue. How do i remove this symbol?
2005 audi A6 3.2l quattro base sedan has a thump to it whenever braking to a complete
My 2005 audi a6 3.2 liter quattro base sedan does this forward like thump whenever braking and coming to a complete stop, does anyone knows what this could be? it feels as if the car got bumped from behind whenever coming to a complete stop.
2005 audi a6 3.2l base sedan does a thump whenever braking and coming to a stop
2005 audi A6 3.2l quattro base sedan radio/MMI not working
My 2005 audi a6 radio/mmi isn't turning on but i hear like a pop sound very small/light as if there's not enough power to turn the speakers on. when problem first started the screen would turn on then turn off and not come on again, now it just doesn't turn on at all. any help?
will.m075, it appears you have a number of issues with your C6, but putting them all on one unrelated thread isn't usually a best practice. Furthermore, have you used the SEARCH function at all?
For example, this could be a cause of the "thumping issues": https://www.audiworld.com/forums/a6-...sound-2901231/
Get your car on a lift and get it inspected by a professional who knows what they are doing, vs guessing on what it could be.
Get yourself a VCDS log and post it, then you'll need to an optical loop to determine the culprit of the failure. Another thing is could be is moisture in the BT module, located under the driver seat, which can cause all sorts of MMI issues...leverage the SEARCH function and you'll see plenty of responses to "BT module change" and troubleshooting the issue.
Good luck and let us know how it turns out.
2005 audi a6 3.2l base quattro sedan does a forward jumpy movement when stopping
2005 audi a6 3.2 sedan radio/mmi not working
Jeremy86
2.0T FSI Discussion
07-05-2017 12:01 PM
Ulilbastrd
12-15-2002 03:57 PM
