Last edit by: IB Advertising
- Audi A6 C6 How to Replace Fuel Filter<br>Step by step instructions for do-it-yourself repairs.
DIY 55k Service 2005 C6
#111
cel light turn on. tiptronic
The car had problem to get normal ,and in 1900-2100rpm it was Hacking, lugging, like engine goes higher Then rpm ( like 4000 rpm. But Only 1900. Always happend when motor is warm. Speciel when i must drive on highway up, lugging, i change new sparks , and new motor oil and filter. Drive so to red line when motor was norm temp , i do That for 30 sek, 3 times in 3 gear. Some say is converter. But now all is ok. Km is 152.000 now 2005 mod. Audi dont find any diagnose, ( but cell light was ok when they check. Will it be ok now? For how long? Was no smoke eksos when i burn" high rpm.
#112
https://www.audiworld.com/forums/sho....php?t=2866244
#113
[QUOTE=r1racer;23853388]Go to your dealer if you want it right away or get it from genuinevwaudiparts.com. Put the year, make and model of your car and search "fuel filter." Get the one for the 3.2 liter. It's $27.20.
They are located in california I do believe so if your east coast it will probably take 5-7 days before you get it.[/QUOTEDRIVSTOFFILTER
AUDI A4, A6, A6 Allroad, A8, R8, R8 Spyder, SEAT E »
274,-
Spar 40%
stk. inkl mva & toll
322 kr
Kjøp
* På lager hos leverandør, 3-6 dagers levering
Kun 79 nok for frakt inkl mva & toll, uansett størrelse!
Fri frakt for nye kunder ved kjøp over 600 kr
Markedspris ca 451 kr
Du sparer: 177 kr
Tips en venn
Art.nr :* 323231 Originalnr.:*
4F0 201 511 C
4F0 201 511 E
4F0201511C
4F0201511E
Generelle produktinformasjon
Filtermateriale av høy kvalitet som beskytter innsprøytningssystemet.
Produktinformasjon
Andre varemerker
Art.nr : 323231
(Aktuell artikkel)
PÅ LAGER HOS LEV. 274,-
/stk.
Kjøp
Art.nr : 139654
PÅ LAGER HOS LEV. 332,-
/stk.
Kjøp
Spesifikasjoner
Diameter 3 [mm] 11
Diameter 4 [mm] 11
Diameter 2 [mm] 14
Høyde [mm] 176
uttak ø [mm] 7,9
Diameter 1 [mm] 74
Diameter [mm] 83
inntak-ø [mm] 9,9
Høyde 1 [mm] 95
Brennstoffberedning Bensininnsprøyting
Leverandør BOSCH
Is this ok ? Where is webshop for Audi i can buy/ shop original??
274,-
Spar 40%
322 kr
Kjøp
Du sparer: 177 kr
Tips en venn
4F0 201 511 C
4F0 201 511 E
4F0201511C
4F0201511E
Produktinformasjon
Andre varemerker
Art.nr : 323231
(Aktuell artikkel)
/stk.
Kjøp
Art.nr : 139654
/stk.
Kjøp
Spesifikasjoner
Diameter 3 [mm] 11
Diameter 4 [mm] 11
Diameter 2 [mm] 14
Høyde [mm] 176
uttak ø [mm] 7,9
Diameter 1 [mm] 74
Diameter [mm] 83
inntak-ø [mm] 9,9
Høyde 1 [mm] 95
Leverandør BOSCH
#114
Just want to thanks the OP again. I just completed the fuel filter change and it all went well. Documentation was right on. Without the documentation i likely would not have attempted all on my own. Much appreciated.
55k service was just performed so the other items was done by the dealer.
#115
Great posts!!
I came back from the dealer and got quoted since I have an engine oil leak ---to do "Reseal rear timing chain (left & right) cover Variators $407 each side ($800 total).
Does anyone have a write up & pics to do this? Thanks a bunch for these DIY vids...its quite helpful!
#116
amazing post i am at 108K but i have done most of that maintenance but i didn't know about the fuel filter that is really what i am going to do thank a bunch very detailed and helpful the mechanic would love this
#117
For the fuel filter part, is it a good idea to let the car run out of gas? People say it could cause issues. I followed the instructions here to replace mine and after scanning the car I get the following fault code which wasn't there before. Researching the code outputs: ECM or ECU. Now I'm concerned
#118
The instructions call for removing the fuse and letting the engine run until it dies. This will throw a code because of open circuit/no fuse.
It's normal and nothing to worry about. Reinstall the fuse, clear the codes and you will be OK.
#119
#120
I actually scanned the system after plugging back the fuse and clearing the fault codes. I will scan it again. Maybe the car just needs some time to rearrange everything.
