Empty batt/ windows not work after chage batt
Hey. I post this wrong place, so I try here.
The Windows on drivers side not work, after battery was empty and I get quick start help. All 3.other windows are ok when I press the Locks / up/ down inside. With the key press they not responding anymore.
What can be the exact problem, it stay open now, and I hope someone can help me here,
Check your fuses
Post on the c6 forum
Post vag-com codes[/QUOTE
I think you have right about the fuse is gone. I find out it is in the luggage rom"
rear fusebox they told me fuse is placed at my car. But. When i read in my manuals book there's stay I have "automatic fuse" and where can i find this? Automatic so will be ok after empty battery, but nothing has helpedafter charging the batt full. Also the light for automatic handbrake light was in panel/ warnings" after starting cable help"?
First thing is to look in your owners manual and you will see clearly where all your fuse panels are. On the c6 there are 3: Driver side door jam,passenger side door jam, right hand side of trunk.
The trunk fuse panel has a window regulator fuse (#10), pull it and ensure it's good
Get a fuse tester, inspect your fuses
Read your owner manual
Post on the C6 forum, since you are going to get a lot more help posting these questions on the appropriate forum for your car
Check your fuses
So did you check the fuse I recommended and look in your owners manual for other possible fuses?
If it's not a fuse, it could be the regulator and you really need a vag for additional troubleshooting.
Hey. I must try to get vag diagnosis because in the manuals book in car stay it is automatic fuse, and this I don't know where sitting, I think in the rear luggage' rom ( stay not printed text on the fuse panels, so I don't find. The fused there are ok ( they I can check ) 10-15-20-30 amp, but are 2 bigger fuses so I don't know function for. Thanks for answers raj
Audi told me that the fuse termosikring thermofuse" and need to vag check diagnosis, and if I could hear a click" in door when I press down the window ( means that is not destroyed Any know about Thermo fuses?
Check your fuses
Check your fuses
Fuse atlas
JacobB
11-01-2007 06:41 PM
SHouTT
09-12-2006 04:10 AM
bostoned
10-11-2005 10:15 AM
