A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
ESP EPC & Engine Light ON
Old 12-05-2011, 10:14 AM
  #11
jujuC6's Avatar
Originally Posted by pcamaj
lolol...
sorry to hear this budddy...
but did u ever take it for a recall on en COILS.
cause it sounds like it might be it ...
Yeah, the coils were done before I got the car two years ago.
Old 12-05-2011, 10:55 AM
  #12
jujuC6's Avatar
Originally Posted by jakematic
Good point, you can check Audi Recalls and Campaigns here by VIN number.
It wouldn't hurt to do a TBA in my opinion.
Colder weather could have caused low voltage in the battery causing it to lose it's settings.
Procedure here.
I just came back from performing the TBA procedure twice to be sure and car still running rough although it seems to have smooth it out a tiny bit. Thank you for your suggestion. I also noticed that after the TBA procedure the ESP light came on. Any other ideas???
Old 12-05-2011, 11:55 AM
  #13
jakematic's Avatar
Originally Posted by jujuC6
Any other ideas???
Well it was worth a try I guess.
I would post up the FULL autoscan here and on the VAG-COM forum.
Additionally you may try the VAG-COM Yahoo Group, but it might take a day or two to get access.
Someone may be able to tell from the DTC's what it going on once they see the big picture.
Old 12-05-2011, 03:08 PM
  #14
jujuC6's Avatar
Default Vag Scan
Here is my scan. I scanned the car before I performed the Throttle Body Alignment. Parking Brake switch and Battery Module faults I had before all this and have the parts, I just have not taken the time to install them yet.
Monday,05,December,2011,09:53:17:51063
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 42 46 47 4F 52 53 55
56 61 62 72 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
-----------------------------------------------------------------Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0040
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A5113C885E436E
10 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 009 - Open Circuit
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 40
Mileage: 169528 km
Time Indication: 0
Date: 2011.05.07
Time: 12:40:20
Freeze Frame:
RPM: 1632 /min
Mass Air / Rev.: 239.8 mg/str
Temperature: 87.0°C
Part Throttle
Load: 38.8 %
Speed: 23.0 km/h
18975 - Low Pressure Fuel Sensor (G410)
P2543 - 009 - Intermittent
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 169530 km
Time Indication: 0
Date: 2011.05.07
Time: 12:42:16
Freeze Frame:
RPM: 1568 /min
Mass Air / Rev.: 234.4 mg/str
Temperature: 87.0°C
Part Throttle
Pressure: 4.9 bar
Speed: 23.0 km/h
16686 - Cylinder 2
P0302 - 009 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00000100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 186123 km
Time Indication: 0
Date: 2011.11.18
Time: 22:57:39
Freeze Frame:
RPM: 640 /min
Temperature: 78.0°C
Idle
Load: 31.8 %
Speed: 0.0 km/h
16725 - Camshaft Position Sensor (G40)
P0341 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 6
Reset counter: 40
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 05:48:57
Freeze Frame:
RPM: 608 /min
Mass Air / Rev.: 261.6 mg/str
Temperature: 82.5°C
Idle
Bin. Bits: 00010000
Speed: 0.0 km/h
16750 - Camshaft Position Sensor B Bank 1 (G300)
P0366 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 40
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 05:48:57
Freeze Frame:
RPM: 608 /min
Temperature: 82.5°C
Idle
Bin. Bits: 00010000
Speed: 0.0 km/h
18538 - Throttle Valve Actuator Module (J338)
P2106 - 008 - Power Limited due to Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 05:49:18
Freeze Frame:
RPM: 1504 /min
Part Throttle
Bin. Bits: 00000000
Hex Value: 0x002F
Hex Value: 0x0046
Hex Value: 0x0068
16685 - Cylinder 1
P0301 - 007 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 06:03:42
Freeze Frame:
RPM: 2432 /min
Mass Air / Rev.: 425.1 mg/str
Temperature: 84.0°C
Part Throttle
Load: 60.4 %
Speed: 119.0 km/h
16687 - Cylinder 3
P0303 - 009 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 06:10:14
Freeze Frame:
RPM: 640 /min
Temperature: 78.0°C
Idle
Load: 31.8 %
Speed: 0.0 km/h
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 006 - - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 06:10:14
Freeze Frame:
RPM: 640 /min
Temperature: 78.0°C
Idle
Load: 31.8 %
Speed: 0.0 km/h
18669 - Oxygen (Lambda) Sensor B1 S1
P2237 - 009 - Pump Current Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 187084 km
Time Indication: 0
Date: 2011.12.05
Time: 06:34:03
Freeze Frame:
RPM: 2336 /min
Mass Air / Rev.: 348.8 mg/str
Temperature: 85.5°C
Part Throttle
Time: 1075.2 s
Bin. Bits: 00000010
Readiness: 0000 0000
-----------------------------------------------------------------Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0080
Revision: --H01--- Serial number: 0072965
Coding: 0000002
Shop #: WSC 01013 444 54617
VCID: 2953ECC480E23D6
1 Fault Found:
17087 - Brake Switch (F)
P0703 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 168866 km
Time Indication: 0
Date: 2011.04.04
Time: 12:35:09
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 24.0
Temperature: 10.0°C
T.B. Angle: 0.0°
-----------------------------------------------------------------Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02327 785 00200
VCID: 2D5B18D4B40A216
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Reset counter: 60
Mileage: 178797 km
Time Indication: 0
Date: 2011.08.19
Time: 09:31:13
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4006
Hex Value: 0x002D
Hex Value: 0x05AC
Hex Value: 0x00FF
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 59
Mileage: 187066 km
Time Indication: 0
Date: 2011.12.05
Time: 05:49:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0025
Hex Value: 0x01AD
Hex Value: 0x00FF
-----------------------------------------------------------------Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0150
Revision: 27070401 Serial number: 10600300100453
Coding: 0000011
Shop #: WSC 02323 785 00200
VCID: E3CF3EEC224E276
Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H36 0040
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 42
Mileage: 0 km
Time Indication: 0
-----------------------------------------------------------------Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 C HW: 4E0 035 729
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 360KO057511709
Coding: 0000003
Shop #: WSC 01126 444 83883
VCID: 234FFEECE2CEE76
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H09 0060
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 235
Reset counter: 40
Mileage: 181008 km
Time Indication: 0
Date: 2011.09.13
Time: 23:15:24
-----------------------------------------------------------------Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0170
Revision: 00000031 Serial number: 00000000349690
Coding: 0524326
Shop #: WSC 01126 444 52994
VCID: DBBF060C1A3E1F6
No fault code found.
-----------------------------------------------------------------Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
Shop #: WSC 02335 785 00200
VCID: E6C927F8D17C52E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Reset counter: 20
Mileage: 179252 km
Time Indication: 0
Date: 2011.08.24
Time: 06:17:00
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Reset counter: 20
Mileage: 180488 km
Time Indication: 0
Date: 2011.09.06
Time: 05:46:00
-----------------------------------------------------------------Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD7103724
Shop #: WSC 00000 000 00000
VCID: 1C3DC510DFB0D8E
-----------------------------------------------------------------Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7D2006294
VCID: 2855E9C09BE804E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 132
Mileage: 168818 km
Time Indication: 0
Date: 2011.04.01
Time: 13:57:00
-----------------------------------------------------------------Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0230
Revision: 10H29000 Serial number: 00359D0846NS
Coding: 0013622
VCID: 2649E7F891FC12E
Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
-----------------------------------------------------------------Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90022043390119
Coding: 0002021
Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
-----------------------------------------------------------------Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0570
Revision: 00200000 Serial number: 4R813EDD4
Coding: 0067263
Shop #: WSC 01013 067 57207
VCID: 1E39CF18C9ACCAE
-----------------------------------------------------------------Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804B2700B7
Coding: 6CFE73C41B1904
VCID: 2757EAFC96F60B6
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 60
Mileage: 168818 km
Time Indication: 0
Date: 2011.04.01
Time: 13:58:24
-----------------------------------------------------------------Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: “v6
Coding: 0035435
-----------------------------------------------------------------Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001942320000
Coding: 0424125
VCID: 2C5D15D08F1028E
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Reset counter: 41
Mileage: 178699 km
Time Indication: 0
Date: 2011.08.17
Time: 19:50:28
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Reset counter: 20
Mileage: 134964 km
Time Indication: 0
Date: 2009.08.24
Time: 07:20:43
-----------------------------------------------------------------Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F5 910 223 D HW: 4F5 035 223 E
Component: DSP-High C6 H14 0310
Revision: PROD_01 Serial number: 00000000016356
Coding: 0000016
VCID: 244DFDF0E7C0E0E
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 53
Mileage: 186026 km
Time Indication: 0
Date: 2011.11.18
Time: 05:19:14
-----------------------------------------------------------------Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000053279
Coding: 0001114
VCID: DEB90F18092C0AE
-----------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 97
Coding: 0035435
-----------------------------------------------------------------Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
VCID: DDBB0814042A116
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 59
Mileage: 187064 km
Time Indication: 0
Date: 2011.12.05
Time: 05:47:55
Freeze Frame:
Voltage: 11.18 V
Count: 244
-----------------------------------------------------------------Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Component: AFS-Modul rechtsH05 0010
-----------------------------------------------------------------Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394L%047508693
Coding: 0000002
VCID: 2E591FD8B90C5AE
-----------------------------------------------------------------Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0400
Revision: 00000000 Serial number: 00000000091326
Shop #: WSC 00999 444 64523
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1563296874
Coding: 344630393135313035442056413031353633323936383734
Shop #: WSC 02136 444 54521
5 Faults Found:
02255 - Voltage Measuring Lead from Vbat
Freeze Frame:
Fault Priority: 4
Reset counter: 138
Mileage: 163669 km
Time Indication: 0
Date: 2011.01.06
Time: 17:20:54
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 6
Reset counter: 247
Mileage: 163593 km
Time Indication: 0
Date: 2011.01.05
Time: 22:51:15
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 163776 km
Time Indication: 0
Date: 2011.01.08
Time: 16:58:34
01336 - Data Bus for Comfort System
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 11
Reset counter: 128
Mileage: 161355 km
Time Indication: 0
Date: 2010.11.20
Time: 14:26:40
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 4
Fault Frequency: 4
Reset counter: 128
Mileage: 160659 km
Time Indication: 0
Date: 2010.11.10
Time: 16:35:17
-----------------------------------------------------------------Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: E9D32CC4C0627D6
-----------------------------------------------------------------Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
-----------------------------------------------------------------Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H10 0950
Revision: 00000000 Serial number: 00000007510660
Coding: 0010900
VCID: 254BE0F4ECFA196
End -----------------------------------------------------------
Old 12-06-2011, 03:29 AM
  #15
jujuC6's Avatar
I do not think this matters but I am throwing it out there just in case. I went from 5w40 to 0w40 Lubro-Moly oil. Today the car is running like hell just like yesterday, please help.
Old 12-06-2011, 05:59 AM
  #16
jakematic's Avatar
I would clear all the DTC's and see which ones come back.
Wondering if a sensor wire got disconnected/loose while changing oil.
Specifically G40 and G300 that are called out on 2011.12.05
Sensor locations can be found here http://www.audi-portal.com/en/diagnostic/sensors.html
Old 12-06-2011, 11:36 AM
  #17
oaktreelimb's Avatar
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 169530 km
Time Indication: 0
Date: 2011.05.07
Time: 12:42:16
Freeze Frame:
RPM: 1568 /min
Temperature: 87.0°C
Part Throttle
Pressure: 4.9 bar
Speed: 23.0 km/h
I would take care of this problem first then recheck.
Old 12-06-2011, 02:31 PM
  #18
jujuC6's Avatar
Thanks a million for the sensor references, jakematic. I will look into investigating sensor G410 at fault. I want to replace it regardless but could not find it at genuineaudiparts. Do you know part the number for sensor G410?
Old 12-06-2011, 02:32 PM
  #19
jujuC6's Avatar
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 169530 km
Time Indication: 0
Date: 2011.05.07
Time: 12:42:16
Freeze Frame:
RPM: 1568 /min
Temperature: 87.0°C
Part Throttle
Pressure: 4.9 bar
Speed: 23.0 km/h
I would take of this problem first then recheck.
Thanks for pointing this out, I am kinda green using the vagcom. I will give the G410 sensor a shot tomorrow and see what happens. Thanks..
Old 12-06-2011, 02:56 PM
  #20
jakematic's Avatar
I don't, but it might be one of these
http://www.audiusaparts.com/partloca...&siteid=215820
http://www.ecstuning.com/Audi-C6_A6-...nsor/ES281480/
Call or email any of them, they can look it up to be sure it's the right part.
A VAG-COM tip is to look for low Fault Priorities - they are the most urgent.
http://www.ross-tech.com/vcds/tour/dtc_screen.html
Best of luck, and keep us posted.
Quick Reply: ESP EPC & Engine Light ON
