How badly am I screwed? P0021
#31
Hey guys. I had the same problem a while back with almost the same exact symptoms. The vagcom can help out identifying the exact actuating valve. Can't think of the exact part of the software to test them with as I don't have it in front of me but its the routine that activates all the engine selenoids etc. You can activate each one manually or automatically. Use the manual mode. For those actuating valves open the hood and get in a quiet place and activate each individually you can hear the click for each vagcom doesent give an error report unless the selenoid on the valve is shorted ... Which usually isn't the case. You can ohm them out till the cows come home and they most likely will read fine because the selenoids are electrically fine. The valve itself is usually stuck so if you don't hear a click then thats the one that is stuck. I then pulled it out and connected it to a power source and could feel the selonoid trying to move the valve. Those valves control the oil flow that pressurizes the automatic timing ,advance /retard of the camshafts. You can pretty much tell which bank/side of the engine the bad actor is on by which cyls are misfiring. Ok that said, yes sometimes the screens, which were covering the ports on the side of the valves get worn and get stuck in the valves and jam them. Now if you have money to spare go ahead and buy a new one. But, there is a simple way to clear out the jam in about 10 min once you have it removed from the engine. Did it on mine about 50k miles ago and no problem since. I posted a procedure on the vagcom forum a while ago but I'll give a quick overview here. Get some mmo to lube and clean the valve. A small nail/tack with a head on it, and a vice grip or pliers to hold the nail about half inch from the head. Put mmo in the ports to lube everything up. The valves are spring loaded so put the head of the nail into the round hole on the end/bottom of the valve and hook the head of the nail on the inside of the hole. Use that to pull the plunger of the valve out. Might take some effort, then push it back in. Keep exercising it like this several times until the spring in the valve allows it to smoothly retract on its own. This frees it up then hook the power source and check that it is operating smoothly. By hooking the hole at the bottom you are not damaging any of the ports or o rings. Reinstall and ur good to go. Look I know its an Audi and you're thinking omg I can't do that but they are not rocket science and are not unique to bag. Jap and american cars have pretty much the same setup on the newer ones. I wouldn't worry about the screens damaging the oil system it would have been damaged already by now.
Now just today I was thrown a P0014 - basically same issue just on the other bank. I will let the forum know if it is the same screen issue.
#32
I am not that technical so will not do myself. In way of an update, the P0021 was thrown about 3 weeks ago, and my mechanic found the small screen blocking the actuator. Fixed.
#33
Now they say that it will cost $10K to drop engine to fix the actual actuator.
Any ideas out there? And what if I just ignore and keep driving it (because there is no way I am paying that kind of money)?
#34
There are 4 solenoids on a 2007 4.2. Two banks, one intake one exhaust solenoid in each bank. There might have been a misunderstanding.
If they insist there are only two than you should get out of there ASAP!
#35
Did Audi dealership replace the wrong solenoids, and then when the P0014 came back on immediately, decided to charge me for the solenoids and also tell me that it would be 10K to fix because it is a timing issue?
#36
Update - I found a mechanic who used to work for Audi so very familiar. He goes through the normal checks for a P0014 (including testing current), pulls the solenoid and finds a piece of screen stuck. He says he will replace solenoid. I say that Audi already replaced 2 solenoids when I took it in for a P0014. He says they replaced both intakes, but the P0014 points to the Bank 1 exhaust...
#37
many Audi dealers are cons in Black Tie
they rip you off just like jiffy Lube but for multiple times more.
In my city of 1.2million there are two shops owned by the same family.
you get screwed there every time UNLESS you buy/lease from them every couple years.
otherwise they get a 'parts changer' to service your $70,000 car !
all will tell you......'find a good independant' and enjoy your car for many years
#38
Little bit of advice
Your post is brilliant btw, I have exactly the same symptoms and I'm looking at completing as you have done. With being a complete newbie and only used to servicing cars generally I wanted to ask what may seem as a very dumb question...
Do you have to drop the oil to remove the valve? I see there is a single fixing but I am nervous of removing and potentially damaging further.
Thanks in advance
Luke
#39
They sit on top of the engine, you don't need to drop the oil level. They will need some force to pull them out, so do not pull them by the plastic connector. Grab them lower at the metal part and pull straight out. You won't damage anything, don't worry.
