A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Key Stuck in Ignition
Old 12-08-2011, 06:30 AM
JJD_FTW's Avatar
Default Key Stuck in Ignition
The last few times that I have driven my '07 A6, the key has gotten stuck in the ignition. It usually takes several minutes of messing around with the steering wheel and putting it in park and drive, etc. before the key will release in park. Has this happened to anyone else. Is there an easy solution that I don't know about?
Old 12-08-2011, 06:50 AM
dokebi1221's Avatar
I also have 07 A6, but never had that problem before...
Old 12-08-2011, 07:42 AM
babytransporter's Avatar
Hey man i have a 05 a6 and when I tell you i had the EXACT same problem I did....I had to replace the key and the ignition switch ,only reason why I had to get a new key is because when I brought the car only one key came with it. However if I am not mistaken the dealership charged $300 for the new ignition switch but that is what you will have to do to solve your problem...As for me with the new key and ignition switch I have not had any problems so far (knock on wood) I hope everything works out for you too
Old 12-08-2011, 07:44 AM
JJD_FTW's Avatar
Thanks for the help. I have a second key, so hopefully its just a matter of replacing the ignition.
Old 12-08-2011, 08:37 AM
haloguy628's Avatar
I had the same problem. The Tiptronic shifting assembly is out of alignment and the ignition interlock is not releasing when put in Park. Simple mechanical adjustment is needed.
If you have some mechanical skills you can do it yourself. To get to the assy you need to take off the center console.
Old 12-08-2011, 03:19 PM
KevinGary's Avatar
Take a look at the TSB library linked in my signature. There is a TSB on the problem in the ignition section.
Old 07-26-2012, 03:16 AM
Reggie6's Avatar
I have an older A8 1997 and it was a simple fix, just replace the ignition switch.
Old 07-26-2012, 03:41 AM
cepausm's Avatar
I had the same issue but my car just would not recognize it was in park so it wouldn't
Release the key. The dealership had to replace a sensor to fix the issue.
Old 07-26-2012, 08:59 PM
RydeOdie's Avatar
I have an 07 A6 as well, never experianced that ever BUT it happened to me in a A4 loaner, I had to play with the steering wheel just like you did and it let go...very strange problem
Old 08-03-2012, 09:49 PM
schuster's Avatar
Sensor in shifter assembly. That was hapen once to me. Moved car forward and back, select parking, drive and rear and key came out. Never hapend again.
Quick Reply: Key Stuck in Ignition
