A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Oil drain plug
Old 08-19-2014, 03:37 PM
typhoon1's Avatar
Default Oil drain plug
I have a 2006 A6 Quattro with the 3.2.
Was always dealer maintained.
I now do my own oil changes and noticed that the oil drain plug has no gasket/washer.
The plug seems extremely light and most likely made of aluminum. It has both an internal Torx and external hex head.
I have changed my oil 4 times now without a gasket/washer and never a drop of oil from the plug.
So, no gasket or should there be a gasket?
I have been tightening it to about 20 ft lbs.
Thanks!
Old 08-19-2014, 06:19 PM
raj99's Avatar
Thanks!
hi typhoon,
I'm almost certain that it has a washer, but I can't be certain since awhile back I installed a Fumoto Qwikvalve and could not be happier. My oil changes went from taking over hour to less than 10 minutes!!
Old 08-19-2014, 07:08 PM
turbo97se's Avatar
There should be a washer. Audi changed washer and plug type at some point .. don't recall exactly when. If you have internal torx like this:
The crush washer is this:
If it is not leaking, you are lucky is all I can say. Crush washers are cheap.
Thanks!
Old 08-19-2014, 09:55 PM
A6Gary's Avatar
Per ETKA 7 for 2006 A6 3.2L, the crankcase drain plug included the seal up thru VIN 4F-6-190 000. From VIN 4F-6-190 001, the seal was separate.
Old 08-20-2014, 02:08 PM
typhoon1's Avatar
[QUOTE=turbo97se;24597335]There should be a washer. Audi changed washer and plug type at some point .. don't recall exactly when. If you have internal torx like this:
My plug does not look like that. It has BOTH internal Torx and external hex. It is made of aluminum and the plug is horizontal; points to the passenger side. I do recall the dealer telling me there is no washer on this type of plug, but I am wondering.
If it should have a washer can someone give me a part number for this type of plug?
Thanks!
Old 08-22-2014, 01:26 PM
Mike141's Avatar
That other one looks like it's from the 4.2? But my 3.2 A6 had same type of plug as typhoon1's with NO washer and I did not have any leaks. But double check with your service dept if no luck here
Old 08-22-2014, 08:31 PM
raj99's Avatar
you're correct Mike...the one with the hex key looks like my old plug, and I have a 4.2. I've never seen a plug like the one in the pic and especially not one within a crush washer...but then again I don't have a 3.2.
Perhaps some 3.2 folks can chime in on the thread?
royriccomini
10-08-2017 04:31 PM
pb18
A6 (C7 Platform) Discussion
05-29-2017 08:48 PM
Slye A4
12v V6 Discussion
11-09-2007 05:43 AM
MM120
12v V6 Discussion
22
10-14-2004 11:08 AM
UrSoccer_mobileĀ®
06-08-2003 11:32 PM
Quick Reply: Oil drain plug
