Pinch Bolt nightmare, what to do NEXT!
#11
Thanks everyone out here who gave valueable tips. I just put the wheels back and un jack the car. Waiting for next weekend to try a shot with using ball joint tool or drill the bolt. My last option will be to take apart and going to machine shop.
One interesting thing i just noticed that i don't have to take a wheel off for pinch bolt job, maybe just jack-up the car little bit to have more clearance.
I tried to compress the spring to see if shock can be replaced without taking a entire assembly off, which looked almost impossible with Autozone spring compressor tool that i have rented, also there are chances of ruining control arm due to lake of clearance to work with.
I will keep you guys posted.
#13
BillM
#15
Wake96c4, thanks for reply.
No i dot have ball joint kit, and not sure if that help at this point, lol. Bolt side is totally flatten after hammering. I should have cut the the bolt before spinning, that way i could have room to push it through the hole using pin chisel.
I'm sure there are people out there with the same situation that i am in.
Cutting a bolt gives some room inside to use chisel hammer method.
http://www.passatworld.com/forums/61...easy-pics.html
#16
Get a good quality air hammer, or, drill them out.
When I did the upper control arm bushings on mine, I heeded the advice of the Audi tech, who said that I should just order new bolt and nut, since he had never seen any of these pinch bolts come out. He recommended an air hammer with pointy chisel to drive them out.
I ended up -not- having a good quality air hammer, so my solution was to drill them out.
Pain in the hind quarters, but access isn't really too bad...
#17
I had the exact same issue when changing the struts in my C5 and in the end had to use a drill to actually drill out the pinch bolt...it was a huge PITA and I went through 2 drill bits and enormous frustration. But, when I was done I made sure that I used anti-seize on the new ones I put in to ensure I didn't have the same issue going forth. I ended up getting rid of the car, but at least the new owner won't have the same issue.
#18
happens all the time. Torch, hammer, and punch. Wrap the rubber balljoint boots with a soaking wet rag to keep them from catching on fire or burning. Get that area hot as **** and pound it out.
#19
theres also the oem tool for pinch bolt removal pn VAS6085
here is a vid on youtube ..edge motors using tool
#20
Ah yes, heat. I forgot about how useful that is when working on seized bolts. Last time I did that with wheel bearings I was replacing, worked wonders on the hub bolts I couldn't otherwise budge.
