A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Service light reset help!
Old 11-28-2010, 09:36 PM
audia6s's Avatar
Default Service light reset help!
Can someone tell me how to reset servvice (oil) light on my 2008 A6. I have VagCom and currently my computer shows me "Service Due since 36 days ago, 600 miles". I did change the oil 600 miles ago but never reset the light.
I guess simple reset in VagCom wouldn't work since I read this on "Ross-Tech Wiki".
"In many of the latest Audi models (2008 and newer), the default "Simple Service Reset" or "Basic Service Reset" choice cannot be used. Instead, you must pick the appropriate choice for your region, for example "#2 Mileage based Service Reset (USA)". But whats is that mean
I don't want to mess anything up I just need the car to think that I changed the oil 600 miles (36 days) ago and for the light to go on when it's the time for next oil change. Someone with VagCom knowledge please help me out before I mess it up thanks
Old 11-29-2010, 04:30 PM
raaizin's Avatar
If you call Ross-Tech they will walk you through it. I havent done it enough times myself to explain it though. I to am a little intimidated by Vag-Com...Ray
Old 11-29-2010, 05:56 PM
audia6s's Avatar
Got it all figured out. Gotta cheap chineese vag com knock off but does everything i need.
Old 03-30-2011, 07:09 AM
marcelll's Avatar
Could you please let me know what "cheap chineese vag com knock off" did you get and where did you get it? (link would be helpful!) Thanks in advance for your help!
Old 03-30-2011, 07:42 AM
SchwarzS6's Avatar
You can give it a try but it probably will not work on the C6 cars. Most of these cables are intended to be used with the Ross-Tech VAG-COM shareware software. The VAG-COM shareware software which works with those knock-offs does not support CAN based cars.
Old 03-30-2011, 03:54 PM
audia6s's Avatar
Not true. Not gonna go into details on open forum though.
Old 03-30-2011, 04:15 PM
am_ver's Avatar
I don't understand - why not? Can you share details of the product that you bought and is working?
Old 03-30-2011, 08:32 PM
audia6s's Avatar
PM sent
Old 03-31-2011, 05:34 PM
djA6ryder's Avatar
Can you PM me as well!!
Old 09-24-2012, 07:59 AM
anthonyi's Avatar
So, am I understanding this right, the ONLY way to reset the service notification for oil changes is through vag-com? There is no button, or MMI option?
Anthony
Quick Reply: Service light reset help!
