Power Steering hose/ATF Cooler line
Went under the car to check if the engine mount had a leak. Well, there was no leak there, but the car had leaks at a few places and I'm trying to figure out what needs to be replaced.
The bottom one appears to be the ATF cooler line - another version is from the Bentley manual, which is return/supply from the radiator.
The top leak behind the belt appears to be coming from the power steering pump. Any usual suspects on what causes the leak here - power steering pump, Banjo bolt, or the pressure hose (4F0-422-893-H)?
Since I am no expert, please correct me if my identification of the parts is incorrect
Does this help with parts id ?
# Number Description Qty.
oil container and connection; parts, hoses; 5.2ltr.; 10-cylinder
1 4F0422371F oil container 1
2 4F0422376A cover for oil reservoir 1
3 4F0422887AH intake hose 1
4 4F0422887AG intake hose 1
5 4F0422893H expansion hose; (flex. hose > vane type pump) 1
6 4F1422893AN expansion hose; lhd 1
6 4F2422893AC expansion hose; rhd 1
7 4F2422893AN expansion hose; rhd 1
7 4F2422893BG expansion hose; use only in conjunction with:; also use:; rhd; 4F2 422 891 T; >>D09.11.2009; 4F2 422 891 T 1
8 4F1422891M return hose; steering gear; cooling pipe; lhd 1
8 4F2422891M return hose; steering gear; cooling pipe; rhd 1
8 4F2422891T return hose; steering gear; cooling pipe; rhd 1
9 4F0422885L cooling pipe 1
10 4F0422891P return hose; (cooling pipe > oil reservoir) 1
11 see illustration:; 145-95
12 4F0422529B non-return valve 1
13 N 0138495 o-ring; A14X20 1
14 WHT000507 banjo bolt; hexagon collared bolt with; hexagon socket head (duo) 1
15 N 0138487 o-ring; A16X22 1
16 N 90807902 hexagon head bolt (combi); M8X20 1
18 4F0422379A clamp 1
19 N 10255601 clamp; 23,5X7X0,6 1
20 N 10347404 socket head bolt with hexagon; socket head (combination); M6X35 1
21 N 10255501 clamp; 17,5X7X0,6 2
22 N 10696502 hexagon socket head; bolt (combi); M8X20 1
23 4F0422113 guide ring 2
24 see illustration:; 614-10
25 N 10527703 socket head bolt with inner; multipoint head; M6X30 1
26 N 90643701 cable tie with holder; for weld pin:; 10X187; 5MM X
27 4F0422173 bracket; return hose 1
28 N 90708802 speed nut; 5 2
29 N 90488005 hex. nut with washer; M6 1
30 N 01508213 hexagon collar nut; M6 1
31 N 10196103 socket head bolt with inner; multipoint head (kombi); M6X18 1
32 4B0422379 spring band clamp; 16X12 1
33 N 90686902 spring band clamp; 23X12 1
34 G 004000M2 central hydraulic oil and; steering gear oil; 1.0 ltr. 1
34 G 002000A2 central hydraulic oil and; steering gear oil; * note technical; * product information; 1.0 ltr.; 2017170/* 1
34 G 004000M7 central hydraulic oil and; steering gear oil; service fluid; 30ltr. 1
34 G 004000M8 central hydraulic oil and; steering gear oil; 60ltr. 1
Thank you Royclark - this is very helpful! Appreciate your help! Looks like my return hose going to the reservior needs to be replaced.
Usually its just those awful hose clamps. Cut it off, and double clamp it with 2 worm gear clamps. Unless its swollen real bad, I cant tell from the picture.
kkii9
02-21-2008 10:46 AM
