A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
rSAP Adapter questions PN:8P0051440A
Old 07-28-2015, 09:44 AM
CaryThompson's Avatar
Default rSAP Adapter questions PN:8P0051440A
I just recently purchased a used 2006 A6 Quattro. I am looking for an Audi rSAP Adapter part number: 8P0051440A that is missing from the center arm rest. It appears that if I had this adapter I could connect my phone up for hands freecalling. Does anyone have any idea ofwhere to start looking? I found one onebay from overseas but would rather buy local or from the US.<o></o>
Thanks,<o></o>
Cary<o></o>
Old 07-28-2015, 02:18 PM
haloguy628's Avatar
The connection in the center armrest is for phone cradle and you can only get 2G Motorola flip phone and old iPhone 2G cradles. It's not for bluetooth module. You should already have bluetooth module installed for handsfree calling but it may be bricked. There was recall for the early C6 to update the BT modules with new SW and FW.
Old 07-28-2015, 02:26 PM
Thanks Haloguy628. If I understand you correctly this recall should still be in effect then.
Old 07-28-2015, 04:10 PM
haloguy628's Avatar
Most likely it's not. The TSB advised dealerships to update the BT module and then update MMI. The problem was that if the SW and FW on the BT module was mismatched and the MMI was updated to newer version it would brick the BT module. Now this was in 2007 or 2008.
You need to get your car scanned with VCDS and see if there is any fault codes regarding the BT module.
Old 01-12-2016, 09:00 PM
Crai6m4ck's Avatar
The connection in the center armrest is for phone cradle and you can only get 2G Motorola flip phone and old iPhone 2G cradles..
Not true. You can get cradles up to iPhone 5/5s
Genuine Audi iPhone 5 Phone Cradle Generation 2 & 3 | eBay
Mojo57
08-01-2010 07:16 PM
rxpclb
05-21-2007 01:11 PM
Mark - Steve's bro'
Audi 100 / A6 (C4 Platform)
09-30-2003 11:39 AM
007 S4
01-13-2002 10:46 AM
Quick Reply: rSAP Adapter questions PN:8P0051440A
