Steering column adjustable does not work - VCDS Basic Setting
Welcome for the first time on your forum.
I became a happy owner of the Audi A6 C6 3.2 petrol
Unfortunately, steering column adjustable does not work. Worked front and back, but not working up and down. I found the topic of the need to carry out a steering adaptations.
Unfortunately, after doing this by VCDS I heard just like a relay, and now does not work any longer in the plane.
In all the instructions that I found it after entering in the Basic Setting and selecting a group of 001 should be like in the picture
But in my first window at the Supply Voltage is DISABLE and ENABLE should be.
What is going on? I checked the fuses steering wheel.
Is it possible somehow trick the VCDs check the movement of the steering wheel? Because it's certainly a fault settings. Previously worked front and back. Now, nothing works.
Please help. I am a layman in these matters.
Thank you.
Thank you.
you followed this? (also did you click the "next" button in vcds to start the basic setting?):
Steering Column Adjustment
Prerequisites:
Steering Column or the Central Electronics Control Module (J519) have been replaced.
Approach all 4 end positions (up, down, forward, back).
[Select]
[09 - Central Electronics]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
cheers/H and welcome! =)
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
J. Patterson (04-10-2023)
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
