A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Brakes without VAG
Old 11-03-2010, 03:26 PM
stroker351w's Avatar
Default Brakes without VAG
I've searched the threads for how to do breaks on an '05 A6 without VAG-COM because I heard it was possible but haven't been able to find it. Can anyone post the link to it??
Old 11-03-2010, 04:01 PM
KevinGary's Avatar
You need a vagcom. Don't chase the urban legend.
Old 11-04-2010, 03:39 AM
69RS's Avatar
vagcom makes the rears easier to do (not needed for the front). I just did all 4 corners (05 4.2) including rotors and did not use vagcom. As other posters have mentioned, on the rears you can remove the parking brake motor (2 torx screws) and manually detract (rotate) the motor shaft and push in the caliper piston. Not too hard at all.
The hardest part on the rears is getting the caliper carrier bracket off to remove the rotor. The lower bolt is next to the axle and in front of the strut. I could only get a 3/8 drive socket in there and luckily had a 2' breaker bar for leverage.
ct-audi-A6-3.2
48
08-24-2020 05:20 AM
byablun
01-04-2018 09:22 AM
Galco
08-21-2009 08:17 AM
gmtalike
11-07-2008 06:16 AM
jdh_A6
12-26-2007 02:41 PM
Quick Reply: Brakes without VAG
