A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Old 07-22-2016, 01:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Transmission Guides
See related guides and technical advice from our community experts:Browse all: Audi Q5 or Q7 Transmission Guides
Print Wikipost
Transmission Fluid Change?
Old 07-15-2010, 05:08 AM
  #51
mystrodo's Avatar
Originally Posted by The_Mizarc
My Audi Dealer didn't want to do it. I think i will insist on it though when i make my next trip for maintenance. Problem is if I were to use turkeybaster's research and walk in with 10 quarts of the ford branded atf I would lose any chance at a claim later on if a problem did arise. So i am forced to pay for the atf there at the dealer. The only alternative being an independent Audi service location.
If the fluid is ZF certified what can they say? if your already past any warranty period a reliable *experienced ZF indie (audi/bmw/vw perfered) will work just fine IMO as long as we're convinced they know the proper method. Although z1racer is certainly an above average mechanic (I'm sure you've read his 55K service) he's not afraid of this car and hopefully when he does his he'll more then clue us in. The job is most certainly a competent DIY'er project and not a complicated one if done by the book..lot's of info here and bimmer forums for walk thru's it such as :
http://forums.5series.net/topic/8812...-drain-refill/
Looking at the fluids in the last picture..is there any question these ZF's need alittle TLC?
Old 07-20-2010, 04:00 AM
  #52
Jersey John's Avatar
Default The continuing saga of the A/T fluid question
Originally Posted by KevinGary
I had mine changed at 35K miles and will do it again at 70K miles. The transmission manufacturer recommneds getting it changed every 45K miles, even though Audi claims it is lifetime fluid.
KG,
Did you do it at the Stealership or did you have an indy do it? Who did it for you?
Old 07-20-2010, 04:05 AM
  #53
KevinGary's Avatar
Originally Posted by Jersey John
KG,
I had it done at the dealership.
Old 07-20-2010, 03:19 PM
  #54
am_ver's Avatar
Originally Posted by r1racer
Thanks...think I'm going to stick with OEM though. I found the correct fluid for our tiptronic (G055005A2 or G060162A2) depending on transmission type. ECS tuning & bluaparts sell it among others. Didn't see any kits though so looked up the parts on audiwholesaleparts/ genuineaudiparts. This is what I've come up with so far as far as cost:
Fluid (G055005A2/G060162A2)- 35-50 x 10 = 350-500
Filler tool-14
Pan gasket- 35
Filter- 70
Filter gasket-22
Drain plug washer- 2
Total-493.00-643.00
Installation doesn't appear that difficult. Bentley is saying that you have to remove the crossbar under the pan, a section of exhaust, drain, take the pan off, clean pan & magnets, replace filter and pan gasket, and then just have to install the pan torx screws in the correct sequence and torque them to the right specs. Filling seems easy enough...just have to get the tranny at the right temp for the top off. Gonna go ahead and order and give it go.
When my TQ converter was replaced at the dealer, they put in G060162A2, quantity = 4. genuineaudiparts.com has this for $41.16 per piece. Do we need 10?
Prior to that, a different dealer performed the chirping sound TSB and put in 8 units of G055162A2 - which are at $33.60.
Now I am even more confused on the quantity of fluid required in our tranny.
Old 07-20-2010, 03:31 PM
  #55
KevinGary's Avatar
I believe that it holds 8.
Old 02-17-2011, 06:48 AM
  #56
audia6fan's Avatar
Buump on this... for those that have done this themselves what about the software update? I've found a couple of threads discussing the need to do this depending on what the original fluid was and what you're replacing it with (ie gold to blue).
Old 02-17-2011, 08:08 AM
  #57
audia6fan's Avatar
Also wanted to throw this into the mix for discussion:
http://prayertr.ipower.com/swbgaz/media/Bg$20Universal$20Synthetic$20ATF$20Application$20C hart$5B1$5D.pdf[URL="http://prayertr.ipower.com/swbgaz/media/Bg$20Universal$20Synthetic$20ATF$20Application$20C hart$5B1$5D.pdf"]
Old 02-17-2011, 08:10 AM
  #58
audia6fan's Avatar
http://prayertr.ipower.com/swbgaz/me...art$5B1$5D.pdf
Old 02-17-2011, 10:29 AM
  #59
am_ver's Avatar
r1, did you change the fluid yet?
Old 02-17-2011, 11:54 AM
  #60
seckler17's Avatar
Default Indy quote
I recieved a quote from my Indy shop for a transmission fluid change, they are quoting aprox $380 total. Quote included 9 quarts of fluid at $25/qt and about 2 hrs labor. This seems relatively inexpensive considering what I have seen others posted they paid.
Quick Reply: Transmission Fluid Change?
