Two codes with '09 S6
I plan to take my '09 S6 to a VW dealer this week for the 55k mile service rather than driving over an hour to a Audi dealer (sorry but I can't do it all myself).
While planning for the service I scanned my car and came up with two malfunctions in 01-Engine and 07-Control Head. I tried searching for the error codes but didn't find anything. I don't know how to cross reference these two codes. Any advice?
Address 01: Engine (BXA) Labels: Redir Fail!
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH03--- Serial number:
Coding: 01050009190F0160
Shop #: WSC 02256 785 00200
VCID: 23450795E219603953D-8076
1 Fault Found:
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 002 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 94536 km
Time Indication: 0
Freeze Frame:
RPM: 130 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Absolute Pres.: 990.0 mbar
Voltage: 9.652 V
Readiness: 0000 0000
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361AG097526013
Coding: 0010003
VCID: 326BF2D1ADE3F9B1A8B-8067
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001244002
Subsystem 3 - Serial number: 0109.12.080000000100010880ÿ
Subsystem 4 - Serial number: 010880ÿ
1 Fault Found:
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 7
Reset counter: 40
Mileage: 91720 km
Time Indication: 0
Date: 2015.02.04
Time: 07:50:15
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0110010
Bin. Bits: 000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 94536 km
Time Indication: 0
Freeze Frame:
RPM: 130 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 21.0°C
Voltage: 9.652 V
Coding: 0010003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 40
Mileage: 91720 km
Time Indication: 0
Date: 2015.02.04
Time: 07:50:15
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0110010
Bin. Bits: 000
Do you have engine light on? If not, I would clear the codes and rescan after a couple of weeks. Sometimes, fault codes were recorded in the ECU when you took the car for some repair. It happened to mine. I took my car to the dealer to fix some noise issue inside the dashboard. The engine light was not on when I pickup the car. After driving home, I scanned the car, it reported a lot of faults related to the controls inside the dashboard.
Voltage: 9.652 V - how old is your battery? Normally you would see voltages over 13 V when engine on or 11 - 12 V when engine shut off. If the battery is really old and losing charge the car will start to utilize protocol shutting off certain systems while parked to prevent further discharge. Then you will see quite a lot codes.
As for the codes. The ignition switch circuit. Can you tell us how many miles is on the odo? You need to compare the mileage (converted to km) with the mileage registered on the code (Mileage: 94536 km). That will tell us if it's a fresh code or not. The code was only kicked out once and it may just be a fluke.
The second code indicates that one of the buttons on the MMI is sticking. Somebody probably spilled something on the buttons. It's really easy to do as the cup holder is right next the buttons. The code is fairly old (Date: 2015.02.04) and activated seven times. Probably it was really cold and whatever was spilled hardened up. Best way to fix this is to get Electronic Contact Cleaner spray and spray the buttons real good couple of times so the fluid penetrates under the buttons.
No check engine light, just the codes.
The mileage is 58k now so it looks like the Engine code was thrown recently (94K km = 58k mi). I might just get a new battery to be safe. I just bought the car recently so there is no telling when the battery was replaced.
Also get some electrical contact cleaner spray and see if those buttons can be unstuck.
mmarcski
08-23-2012 04:56 AM
vincent9993
VAG-COM Discussion
05-18-2004 12:11 PM
