Where can I find a 14 pin to 10 pin headlight adapter
I'm looking into an LED headlight retrofit. I currently have a 2005 A6 4.2 Quattro S-Line with stock HID.
The headlight I'm looking to retrofit has a 10 pin connector as my stock HID headlights have a 14 pin connector. So in this case I would need a 14 pin male connector to a 10 pin female connector.
Anyone know where I can find one?
Also, provide more info: are the LED retrofits from a 09-11 model? Are they aftermarket? Are you just looking to get the DRL LEDs or ??
Unless you know exactly the correct pinouts for the new unit and map to the older unit, you will be SOL. Considering the issues you've had doing a similar retrofit with your rear lights https://www.audiworld.com/forums/a6-...ights-2908489/ ...which are a LOT easier, I personally would just get refurb units to replace your "bad" ones.
I found the diagram for the 14 pin connector and what wires are for what and I'm almost positive I can figure out the map out for the new head lights... these new headlights are designed to work only for the A6 C6 model without Factory HID so I need to convert the connecter back to a halogen model 10 pin.
Here's a pic of the aftermarket headlights.
There's a lot of threads on these, but here's one to get you started on a possible solution:
https://www.audiworld.com/forums/a6-...ation-2879463/
And here's the pin assignment, onboard power supply control unit -J519
Connector A (10-pin)
Pin 1: Daylight driving light front right
Pin 2: Main beam right
Pin 3: Fog light front right
Pin 4: Dipped beam right
Pin 5: Terminal 38 right
Pin 6: Daylight driving light front left
Pin 7: Fog light front left
Pin 8: Main beam left
Pin 9: Terminal 31 Power
Pin 10: Dipped beam left
Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Central Electric I J519
Good luck with those...keep us posted on how the install goes for you and if these ever work out for you.
